Fat front tire
Discussion in 'XJ Technical Chat' started by yamama, May 3, 2008.
  1. yamama
    yamama New Member
    crossville, tn
    What is the largest size front tire (fattest tire) that can safely be put on a 1980 XJ650G?
  2. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    The size they list in the manual, 3.25 or 3.50 X 19 for the 1.85 X 19 rim or 100/90-19 as they are now called. If you try a larger one it will probably rub the fender and will screw up the handling by making turning slower and is likely to wobble.
  3. MaximumX
    MaximumX Member
    Ottawa, Canada
    Okay... So why would it cause a wobble? Assuming the tire is balanced and aligned with the rear is there any reason it should wobble?
  4. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Assume nothing.
    I just had a new front tire balanced and I'll be taking it back to them for a re-balance as I have a shimmy starting at around 82mph.
    Anybody a fan of them Dyna beads ?
  5. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    A wider tire will make it more LIKELY to wobble since it was designed for a narrower tire. I don't know why for sure but I tried it once and it did wobble. Actually anything that throws off either the front or rear balance will make it wobble. My big heavy XS1100 uses only a 100/90-19 tire so that should be more than enough for just a 650.
  6. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Don't make me and AZ get into another arguement about those.
    I have them in my tires with no other weights. And the bike rides more smooth than ever before.
  7. RickCoMatic
    How much does Dyna Beads cost?
    And then, ... what do they do?
    Offer an explanation of how the product works and why they (would or are) superior to conventional wheel weights which don't move from their placement spot once affixed to the wheel.
  8. wink1018
    Muncy, Pennsylvania
    just go to their website and read about them.
    But for the quick and easy... They align themselves around the tire during rotation. For reasons that only Physics can explain, they group around the areas that require extra weight to aid in balancing the rotating tire. So, basically, it balances itself while you ride. (True Dynamic Balancing)
  9. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    Those Dyna beads sound like they are smarter than the average bike owner, or wink anyway. Don't they magically balance your tires while they suck money out of your wallet too?
    Hey, if you guys want to see something else really stupid go to U tube and search for "Hydrogen gas savers" or "HHO", there are lots of idiots who think they got double the mileage on their cars using hydrogen they generated from a Mason jar! What's even more funny is if you search for videos on magnetic motors you can find other idiots who claim they have a motor that runs on NO power!
    The funny thing is lots of them use 2 batteries! LOL
  10. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
  11. ryan_975
    ryan_975 Member
    Conway, AR
    There's nothing magical about it. A tire bounces and wobbles when it's out of balance. What causes an imbalance? one part of the tire weighing different then the rest.
    Take a simple electric motor and attach a blade to it. When you turn on the motor it spins and wobbles and is generally uncontrollable. Now take a second blade and attach it loosely to the motor so that it spins almost freely. Now turn the motor on and see what happens. The whole contraption will bounce and shake for second until the second blade spins around and counter balances the first blade. Then the whole thing spins smoothly. The same concepts work for tires.
  12. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    Anyone who thinks that little beads know where to go and can magically balance a tire is a fool and like they say, there is one born every minute.
  13. Polock
    i have a bag of them right in front of me, cost 10$/2oz for 2 tires
    unfortunately i don't have anything to use them on right now
    looks like there are 4 opinions about them
    1 never heard of them
    2 know what they are, never tried them
    3 tried them, worked, use them all the time
    4 junk, for fools, never tried them
    but i never hear "tried them and they don't work"
  14. ryan_975
    ryan_975 Member
    Conway, AR
    Like I said, it's not magic, it's physics. They don't have to"know" anything. They don't seek out the spot that creates a balance. They bounce about inside the tire (so to speak) bacause of the vibrations cause by an imbalanced spinning mass. It's when they land in the spot that's the cause of the imbalance the wieght of the ball balance the tire out and centripetal force keeps it there until the tire stops spinning.
  15. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    We're going to have send this to "Myth Busters" and have them run a test on them.
  16. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    Just because you can repeat a lot of nonsense like that doesn't make it true!
    Do you also play the lottery, visit psychics and use homeopathic medicine?
  17. ryan_975
    ryan_975 Member
    Conway, AR
    As a matter of fact, no I don't play the lottery, visits psychics or believe Jerry Springer is real.
    Just because you can't grasp the very simple physical properties involved that make it work doesn't mean it's snake oil.
    Magnetic cuffs that "reorganzie" hydro carbons to burn better is a scam because hyrdo carbons aren't magentic.
    vortex throttle body spacers are a scam because by the time the air reaches the fuel it's been diverted so many timest that the "vortex" is destroyed. However, Chevrolet uses the same technique in their Vortec engines, they just do it at the head rather than the intake.
    Bring up some other scams and I'll tell you why they don't work. But the basic principle behind a imbalanced spinning mass with another loose mass inside is subject to the laws of physics.
  18. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    >But the basic principle behind a imbalanced spinning mass with another >loose mass inside is subject to the laws of physics.
    Only in your world!
    Actually if there were loose beads in there they would just bounce around harmlessly and do nothing unless you had a bulge in the tire causing one part to stick out farther then the rest of the tire then centrifugal force would probably cause them to stay in the bulging part most of the time which would actually throw the tire more out of balance and of course when you stopped they would just drop to the bottom. You could do the same thing by putting sand inside the tire but I wouldn't recommend that either.
  19. RickCoMatic
    Yep.
    I looked it up in my old college Physics Book.
    Centripetal Force would cause the beads to collect anywhere there was an imperfection to the Gyro force. That the Inside Diameter of the rotating tire is spinning would cause and "Load" to see the surface where the Gyro force is out of balance.
    Just like the Washing Machine adjusts itself to spin and unbalanced load.
    Once the beads are in motion on a fast spinning inner diameter, Centripetal Force will make them collect at the point where there is an imbalance.
    Nice product.
    I wonder who thunk-it-up?
  20. 07spacker
    07spacker Member
    Utah
    somebody put a link so we can see what these beads even are
  21. RickCoMatic
  22. Polock
    while you guys were typing, i was out testing, see general lounge post
    by the way a bigger tire is not recommended on my bmw, they sat it makes for sluggish handling
  23. ryan_975
    ryan_975 Member
    Conway, AR
    Since I live in the real world where the laws of physics apply, you're absolutely correct. By the way, which world (interpreted as maybe "dimension") do you live where physics aren't the same? I know a few scientists that might like to talk to you.
    Mostly correct. but if there was a bulge in the tire you'd have more to worry about the balance. Where you went wrong though is that there is no such thing as centrifugal force. There are centripetal and inertial forces; the two combined are what people mistakenly call centrifugal force.
    No they wouldn't stop and drop to the bottom. They'd contiue to travel around the inside of the tire until the forces of friction and gravity slow them down enough to stop at or fall to the bottom. To simply drop to the bottom when the tire stopped would violate the law of physics that state "An object in motion stays in motion until acted upon by another force." It's Newton's first law of motion, something taught in elementary schools of most of the US and I'm sure other countries.
    Sand particles themselves don't have enough mass to impact the balance of a tire. Collectively, the aren't responsive enough to react to an imbalance to actually stabilize the system.
  24. tomestl
    tomestl Member
    St Louis, MO
    When you stop do all of the beads settle to the bottom of the tire? Does it feel out-of-balance each time you proceed from a stop, and balance as you accelerate? Any noticeable difference under braking, or braking and cornering?
  25. MaximumX
    MaximumX Member
    Ottawa, Canada
    Hmmmm... Couldn't you do the same thing by putting a few ounces of water in your tire?
  26. RickCoMatic
    Not likely.
    It would be very possible to have the water heat-up and cause a mishap.
    I don't know what kind of temperatures are generated inside a tire.
    But, I do know that you can expect the tire to expand if you are running it fast on a paved surface. And with no way to cool the tire it wouldn't surprise me to have the water find its way out ... on way or another and render the experiment a bad idea.
  27. tomestl
    tomestl Member
    St Louis, MO
  28. MaximumX
    MaximumX Member
    Ottawa, Canada
    Bested by science again... Curses!!
  29. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Water might be a bad idea.
    The inards of the wheel for one.
    The inards of the wheel...rotting??
    The valve stem corrosion
    If it gets hot enough it will evaporate :D
    AND mosquitos breeding ;)
    IDK anything about water in tires, BUT those are the reasons I wouldnt try it first.
    OTOH, Guys this is a forum for discusion and civil conversation. Please try to treat everyone as well as you expect to be treated. For others they see these arguements INSTEAD of the facts they prefer to learn. NOBODY wins when there are arguements back and forth.
    Just the way I THINK it should be done like this(My opinion is ONLY my opinion and I try to rarely bring it up w/ thousands of strangers)
    A simple statement like "They worked for me...1979 XYZ Bike 123 Tire"
    Or "They totally messed up my handling...1990 LMNO Bike 534 Tire"
    OR "My physic teacher said it wont work because.........."
    This is supposed to be a place to SHARE knowledge, and EVERYONE is intitled to their opinion(within reason...Harley boys ;) )
    If I was new to this forum and I saw arguements going on I would think...
    1) If I ask a question, will they even answer it?
    2) What happens if someone starts arguing with me, will this be a comfortable place to visit?
    3) I might discount the info given by someone because now they appear submisive, but they know TONS of valuble information.
    I am not singling anyone out here, this thread is just the straw that broke the camel's back. I have seen other threads that kinda upset me. I really came in here to get info about A FATTER TIRE, then the atmosphere change quite quickly to unsavory subjects.
    LETS ALL BE FRIENDS OR ATLEAST AQUAINTENCES :)
    [/rant]
  30. gcrick
    gcrick Member
    near Austin, Texas
    Dyna Beads
    question for those who have bought/tried Dyna Beads:
    Do they appear to be simply styrofoam beads? I'm wondering if we might try regular plastic or foam beads.
  31. tomestl
    tomestl Member
    St Louis, MO
    Re: Dyna Beads
    Website says they are a 'high-density ceramic'.
  32. Danilo
    Danilo Member
    Vancouver canada
    Sand bits?
    There is little reason ANY Moto tire needs more than 5 gramms balance weight. Big lumps 'o lead mean yer tire mounter is a Moron or you wheel is dangerously damaged.
    Tire come from the assembly line with 2 marks one is Tire's Light spot the other is the tires hi spot. Any tire installer with any idea of their job will place the tire on the rim to best advantage.. ergo the 5 gram rule of thumb.. which should be all a decent mounting/balancing job will end up with.
    Kinda throws the need for errr.. Dyna Beads.. right out the window.
  33. kevineleven
    kevineleven Member
    Columbus, Ohio
    I use them and they work great. Everyone can hate on the idea for whatever reason they choose, but to put it quite simply--- THEY WORK. You cannot tell they are in there in any negative way, and I've been to 116mph with them. Disbelievers can go straight to the tire shop for a mount and balance.
  34. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Imay go to a fatter front tire anyway. I've done it before and it didn't seem to make any big difference in sluggish handling as stated.
    The Dyna beads sound interesting. I may just use packing peanuts and keep the tire from going flat!!! LOL
  35. toastturbo
    toastturbo New Member
    Re: beads
    I just went through all the tire balancing threads. It's like the fricken republicans and the democrats. I never heard of dyna beads until a week ago when they where mentioned in some other thread. I always mount my own tires and balance by resting the axle between two kitchen chairs. So I figure what have I got to lose, how accurate can that be. I had no weight on the rear 2 fives and a 10 on the front stem. Dump $12 bucks worth of beads in, can't tell the difference. Simple cheap I'm convinced.
