Seafoam is Back!
Discussion in 'XJ Technical Chat' started by ArizonaSteve, May 6, 2008.
  1. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    Walmart has just setup a big display with tons of legendary Seafoam in the automotive department. It's about $6 a can for you guys who need to clean your carbs but they aren't really that bad and you don't have the time or place to do it. Just pour in about a 1/3 to 1/2 a can and let it do all the work.
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Yup, good idea! I make a habit of running Seafoam a couple times during the riding season to keep things cleaned out as preventive maintenance. It's alot better than having to tear into the carbs.
  3. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    Local PepBoys carries it here, will have to check out WallyWorld and see if they have it in stock.
    Our local Carb Clinic organizer, Shadowhawk, was able to arrange some "samples" at last years carb clinic. :D
