clutch slipping
Discussion in 'XJ Technical Chat' started by chadly89, May 26, 2008.
  1. chadly89
    chadly89 Member
    brownsvalley california
    i have a 81 xj550r seca and its got a new clutch cabe and it is adjusted correctly, i think, and when i drive it hard in the higher rpm's 9-11 and if i shift using the clutch and get on it again WOT it will slip and i have to let off and get back on it again, if i shift without the clutch if will shift and hold fine till about 100mph then when i put it in 5th and tuck down and open it up it the rpm's will go up about 1k and it won't accelerate, then i have to let off and go again, but at slower speeds and rpm's all 6 gears hold and work fine
  2. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    What kind of oil are you using?
    Any oil that's got "Energy Conserving" on the label can cause clutch slipping.
  3. chadly89
    chadly89 Member
    what would be an oil that anyone would recamend?, keep in mind i ride this thing hard
  4. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    I use Mobil 1 Racing 4T 10w-40 in both my R6 and my Seca.
    It's a motorcycle-specific synthetic and will handle any abuse you give your bike.
