!!!!!PARTING 1982 MAXIM 650 YCIS, UPDATED WITH PICS!!!!!
Discussion in 'For Sale, Trade/Swap, Wanted' started by BERTOZZI, May 28, 2008.
  1. BERTOZZI
    BERTOZZI New Member
    Arizona
    HELLO...
    IM PARTING OUT MY BIKE...
    THE FOLLOWING PARTS ARE ALREADY GONE:
    SEAT
    GUAGES
    SIDE COVERS
    HEADLIGHT
    GRAB BAR
    HEADERS N EXHAUST
    CARB BOOTS
    ___________
    EVERYTHING ELSE NEEDS TO GO..
    I HAVE A GSXR THAT NEEDS A MOTOR SO IM SELLING MY PARTS TO GET MY GIXXER BACK ON THE ROAD.
    IF YOU NEED IT... IVE PROBABLY GOT IT
    PLEASE HELP ME GET BACK ON THE ROAD
  2. minnMaxim
    minnMaxim Member
    Minnesota
    Re: PARTING 1982 MAXIM 650 YCIS, LET THE FEEDING FRENZY BEGIN
    My starting button has completely fallen out of my 550. So I am looking for the right starter switch.
  3. chacal
    I've got the starter pushbuttons to replace the missing ones:
    Control Switch Hardware:
    HCP1072 aftermarket control switch PUSHBUTTON & SPRING SET, this round black plastic button correctly replaces broken or missing original starter pushbutton (on the right side control switch) and horn pushbutton (on the LH control switch). Comes with the contact spring. Slightly longer than stock but fits and looks just great once installed. Fits all XJ550 and XJ650 (except Turbo) models: horn button on the left side switch unit, starter pushbutton on the right side switch.
    $ 9.50
  4. RickCoMatic
    I know a guy that need the Handlebar Controls -- Left and Right.
    Compllete with the Brake and Clutch Switches.
    How much for the set?
    (Will these go on an 80 Seca 650 he asks? Me tinks so.)
  5. BERTOZZI
    BERTOZZI New Member
    Arizona
    I THINK I STILL HAVE EM... I GOTTA LOOK WHEN I GET HOME. ILL RESPOND ASAP.. ILL EVEN SEND A PIC IF I CAN FIND EM. I DISMANTLED THE BIKE N PUT EVERYTHING IN ZIPLOC BAGS..
  6. weoxstan
    weoxstan Member
    Central Michigan
    I am looking for a fuel tank that is in good shape, IE: not leaking, no major dents, and clean inside. How does yours look?
  7. huckersteve
    huckersteve Member
    Seattle, WA
    What you need to get for the fork, front wheel, and front brakes? And will it all work (I'd imagine yes) on my 80' 650 Maxim?
    My brother lives in Scottsdale and might be able to pick the stuff up for me and ship it here..
  8. richroszel
    richroszel New Member
    Flowery Branch, GA
    Hi. What would you charge for the turn signal flasher relay (I think that's what it's called) and, while you're at it, for the turn signal switch itself? I just bought a used XJ650H Maxim and the previous owner took all the turn signals off. (I have to have them here in GA.) While I do have them mounted, they aren't working yet and the switch and relay are my next things to check.
    Thanks,
    Rich
  9. Jzap99
    Jzap99 Member
    Mississippi
    looking for a great front turn signal
  10. leondegrance
    leondegrance Member
    Saginaw, Michigan
    Do you still have the carbs? I am in search of two good needle and seats.
  11. bpberk62
    bpberk62 Member
    <a href="http://maps.google.com/maps?q=47.989922+-
    Do you still have the Mirrors?
  12. BERTOZZI
    BERTOZZI New Member
    Arizona
    Mirrors gone
    front turn signals gone
    turn signal flasher relay gone
    wiring harness gone
  13. caddymankc
    caddymankc New Member
    How much do you want for the crash bars?
  14. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Believe it or not, you could probably replace your right and left controls with brand new ones from the dealer. I switched out the ones on my XJ650 last year for like $135 for both. Hope it helps.
  15. BERTOZZI
    BERTOZZI New Member
    Arizona
    Gas tank gone
    engine guards gone
  16. badams201
    badams201 Member
    Tennessee
    still have the carbs? If so, pm me.
