Factory Settings for Mixture.... WOW!!!
Discussion in 'XJ Technical Chat' started by leondegrance, Jun 3, 2008.
  1. leondegrance
    leondegrance Member
    Saginaw, Michigan
    I just pulled the brass plugs on my 650 and noticed that the factory mixture settings were all over the place.
    I had one screw at 1.5, and two at 3 and 1 somewhere around 4 or 5. How is the bike supposed to run properly like that?????
    I readjusted all of them to 3 out and now she purrs like a kitten. I am going to plug chop over the new couple of weeks.
  2. philbrewer
    philbrewer Member
    Livonia, MI
    What model and year is your 650? My 650 Maxim was very similar.
  3. dlanthripe
    dlanthripe Member
    OKC,Oklahoma
    I haave never looked at mine. How do you know if it is at a 1.5 or 4? and what is it supposed to be?
  4. leondegrance
    leondegrance Member
    Saginaw, Michigan
    its a 1983 XJ650 Maxim
  5. leondegrance
    leondegrance Member
    Saginaw, Michigan
    Count the number of turns it takes to get to the bottom. I have read that starting around 2.5 to 3 turns out, then plug chopping works well.
  6. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Mine were about the same. 1.5 to 5 turns out!
  7. bluepotpie
    bluepotpie Member
    Londonderry, NH
    I'm unfamiliar with plug chopping? What is it?
  8. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    THIS IS RICOMATIC'S METHOD.
    **"Some of the tuning you need to do you can do without hitting the road.
    Put some new Plugs in it.
    Lean-out the Pilot Mixture Screws IN ... 3~5 Degrees ... not much.
    Run the bike.
    Set up an electric fan for cooling.
    Rev it up to 5,000 rpm and hold it for 15-seconds.
    Hit the Kill switch.
    Look at the Plugs.
    If you are still Rich you'll see it and hear it.
    Based on the performance after Leaning-out the Mixture you'll have to make further adjustments.
    Start the bike.
    Let it Idle.
    Open the Throttle and listen to it coming off-idle.
    If it boggs-down before grabbing the Main Fuel Supply ... your still too Rich
    If it sputters and coughs ... you have a Lean condition.
    You will be tuning to achieve a seamless transition from Idle to when the Throttles Open.
    This you will HEAR.
    This you will also see as you examine the Plugs.
    Plugs that are too clean will require a few degrees of Richness
    Too Rich and you tweak the other way.
    Hold the Bike at 3,500 rpm.
    Listen to the exhaust note.
    If the note is unsteady ... (Pop, pop-pop, poppidy-poppity) ... tune-out the miss.
    Tweak the Screws a few degrees in each direction until that unsteady note disappears.
    Once the unsteady exhaust note is addressed ... you are ready for some road tuning.
    BRING EXTRA PLUGS IN CASE YOU FOUL THE ONES IN YOUR BIKE.
    Go somewhere where you can do tuning runs.
    An industrial park makes a good location.
    Run the bike for a few minutes and then do a wide open throttle Plug Chop.
    Take the bike right up to high revs ... kill switch and coast to a stop.
    If you set up a table with your tools and Plugs you can coast to your work station.
    Examine the Plugs.
    Closely.
    Make individual tweaks to those that ate rich or lean.
    Stick-in some cleaned plugs. (Carb Cleaner and toothbrush)
    Repeat the run.
    Concentrate on getting the Mixture set-up to seamlessly transition from Idle to off-idle.
    If it won't "Get-out-of-the-hole" ... make Mixture adjustments to give it enough richness to get going.
    After a few runs you'll find Plugs that don't need adjustment and one or two that do.
    Make the adjustments to the ones that need the tweak and do further runs.
    Before too long you'll fine that you have arrived at where there is no further adjustments to do and the bike is accelerating without delay.
    Bring all the tools home.
    Ride it.
    Do a daily inspection to insure you aren't too lean.
    If you get it dialed-in doing Plug Chops ... you'll love the results!
  9. bluepotpie
    bluepotpie Member
    Londonderry, NH
    This seems like an alternate method to colortune plugs. is this accurate?
  10. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Yes.
  11. RickCoMatic
    Supplemental to Colortuning, actually.
    That is tuning for Off-Idle Mixture.
    I find that Colortuning gets you a good Idle and not quite enough extra for sustaining the Mixture to Ignition when you open the throttles and the rush of fresh air momentarily is without Main Jet Fuel Supplied.
    This Plug Chop corrects the Mixtures so the bike won't hesitate or bog-down when you go to get out of the hole.
  12. MiCarl
    I'd be suspicious that someone was in there previously if my screws differed by more than 1 turn. It is possible to obtain replacement brass plugs, or at least it used to be.
    Be aware that not all of our mixture screws have the same thread pitch. On the 650 the thread pitch was reduced in 1982. So the factory setting on an 80 or 81 is closer to 2 turns out, and the 83-84 are 3ish.
    If you've got a bike where some of the carbs on the rack were replaced your mixture screws may not all have the same pitch.
  13. RickCoMatic
    Very, very good point.
    That's why I have switched from FRACTIONS to DEGREES.
    Once you settle-in to where you have a very good Idle and are Tuning for the seamless application of power coming 0ff-idle ...
    It will just be a matter of DEGREES that the Screw needs to be turned.
    A very small amount.
    You can actually go from too Lean to too Rich within a quarter of a turn ... once the Pilot Mixture Screw is within parameters of sustaining Idle but not yet providing enough supplemental Mixture to sustain Ignition coming off-Idle.
    I'm presently adding some Richness to my 750 because its getting warmer out and I want it to run a bit cooler.
    I added 1.5 Degrees of Richness to the Pilot Mixture Screws and have a great Idle and less power in acceleration ... but a slower burn rate not as hot as the previously tuned-in one with a Leaner, more explosive Mixture.
  14. schwarztrader
    schwarztrader New Member
    Hillsboro, OR
    Ok, I have a stupid question regarding the idle mixture screws: Am I correct in my thinking that turning the screws counter-clockwise gives the bike more gas and making it "richer" while turning clockwise gives it less gas and making it "leaner"?
  15. Ass.Fault
    That is correct
    IN for Leaner
    OUT for richer
  16. jim123
    jim123 Member
    Chicago,Il
    Maybe I'm colorblind but I got my 82 650 Maxim running and used the colortune plug to try and set the idle mixture. I noticed there was a lot of flickering of the cyclinder. Sometimes it would fire brightly and you could hear it in the way the bike ran. Anyways, to make a long story short, I set each cylinder so it fired the same every time it was supposed to, blue like a gas stove burner flame. It ran really nice but you could taste the exhaust if you were within 20 feet of the exhaust pipe. Great throttle response and power. Drove it for 10 city miles on side streets. The bike was nearly out of gas before I started off so I added a gallon of gas. By the time I got back, the tank was nearly empty again. Maybe a better way to set the idle mixture is to use a vacuum gage or better yet the carb sync tool that measures all 4 at once. Get the highest reading at each carb with the smoothest idle when the YICS tool installed? I did tune ups this way on cars and got good results(no YICS tool for old v8 cars). I'm trying this next because the colortune didn't work for me but maybe I'm colorblind.
  17. RickCoMatic
    The Blue you get from Colortuning is NOT perfect. It's within the "Window" of Fine-tuning.
    Usually, NOT Rich enough to sustain a smooth transition going Off-Idle onto the MainJet Supply when the Throttles are opened.
    You are within the Fine-tuning arena if you have the Carbs set-up for gas stove blue.
    Now, you want to fine-tune the Mixture to where you have Plugs that show you you are on the money.
    If you feel the Bike is too Rich, you'd "Feel it" off-the-line. The transition to Main Jets will be late or not at all.
    You have to observe the Plugs very closely, now.
    Look at them to see how the Mixture is regulated.
    If you find that the Plugs are too dark ... Lean-out the Mixture, some.
    If you find a Plug thats too clean, add some Mixture to the Cylinder.
    The process of adding Richness or Leaning-out the Hole isn't going to require much of an adjustment.
    Probably within just a few degrees. Because the Bike will let you know if you have gone too far or not enough just by looking at the condition of the Plugs.
    With BLUE showing during a Colortune, it usually means that you are adjusted for Idle.
    Finding the supplemental Richness to the Mixture to carry the acceleration of the engine over until the Main Jet Supply Kick in is the key element in the Fine-tuning.
    I doubt if the Pilot Mixtures need much of a tweak.
    If you think your bike is a Gas Hog after Colortuning ... you need to look elsewhere, too.
    Stuck Diaphragm Pistons not closing fully after throttle closure will waste plenty of gas and give you a false Plug Read for excessively Rich.
    See that your Diaphragms are rising and falling without chatter, binding or sticking.
    If they are not and you have:
    A strong and steady Idle.
    Seamless transition coming off-idle.
    Plugs that aren't excessively dark.
    You are IN.
    You're tuned.
    Maybe BEFORE you got Dialed-in,, the Bike was running Lean and you weren't aware of it.
  18. SecaDan
    SecaDan New Member
    Appleton, WI
    If I understand correct, to get a good ballpark of where to set your carb mixture screws to factory is to screw them in all the way then unscrew 2 - 3 turns? (82 650 Seca)
  19. osage
    osage Member
    Frost Bite Falls, MT
    yes SecaDan, as I understand it 2-1/2 to 3 turns out should be a good starting point.
    ideal setting will vary from one bike to the other depending on milage and condition, altitude can also have an effect.
  20. plansea
    plansea Member
    My carbs were set to about one and and eight of a turn out when I started "plug chopping"
    I thought they all looked not too bad at this setting except number three was very sooty.
    I moved the settings out in stages until they are all at about two turns out
    except number three that I left at the original setting.
    Number three seems to be cleaning up with each run. Darkness and rain put an end ot the tests for today.
    Any comments would be appreciated, I may have a float problem or something else with number three.
    The problem with number three was a leaking petcock diaphragm. The vacuum line that connects to the petcock is only connected to number three carb.
    The low end had improved, and it starts with no choke now. It pulls better from a stop sign now, but I cruise at 100km/hr (60mph) at 5k instead of 115 km/h before tinkering. Hmmmm...
  21. cycleman
    cycleman Member
    Regina, Saskatchewan
    I'm curious about the thread ptich. Wouldn't that mean the carbs ( at least in the pilot jet area) would be different. I'm not sure how they would be interchangeable. Anybody got a picture of the different pilot screws or something from Yamaha on this particular issue.
  22. plansea
    plansea Member
    I think I am going to be close to 2 turns out for the initial setting start point. My bike always starts right away, so I think it is pretty healthy and even one turn in or out just means I may or may not need to play with the choke more or less. I think I may have an sticking slide on number three
    because I didn't adjust the mixture on number three but now the plug is starting to look the same colour as the other three.
    My other theory is my bike being a YICS version hs something to do with it, but that is probably not correct. At two turns out I can ride at idle speed or a bit less even up a bit of hill, I couldn't do that at the original just over one turn out setting. I think I am going in the right direction. I'll run a few hundred miles and maybe put in new plugs and start "chopping" again.
    Stay tuned !
  23. RickCoMatic
    I think we are at the point in time where everyone should be aware of the possibility that their Diaphragm Piston Bores need to be de-oxidized and re-finished.
    Just the time factor, alone is sufficient to have caused the Bores to "Ox-up" and diminish the performance of the Bike due to Piston Lag or sticking.
  24. hman1169
    hman1169 New Member
    Western Mass
    First post... I have to say Thank you before anything... I think I am going to learn a lot in this forum...
    I purchased my first bike, and I am having some problems with it... I have a Maxim 650.
    I have no midrange throttle... It is running really rich... and reading under this topic, "Factory Settings for Mixture... WOW!!!" -- I find myself with a question for anyone with the patients to teach someone who is mechanically inclined but unfamiliar with Motorcycle Carburetors...
    I have pulled all four carburetors off, pulled the bottoms and tops, pulled screw in jets and ports soaked everything in carburetor Chem Dip, except the body of the carbs or the rubber parts... Put it back together and put it on the road, It is running better but it is still burning rich... the only adjustment screws I can see are on the bottom of the carburetors... Are those screws the ones you are talking about as the brass plugs? It seems if I loosen those that gasoline will drip out of the bottom of the carburetors... If those are not the idle mixture screws, where are they? My bike is burning EXTREMELY Rich...
    Oh wise ones of XJBikes.com. Is there someone out there who can give me some insight?
  25. plansea
    plansea Member
    The screws on the bottom are the carb drain screws, the idle mixture screws are on the top. I am going for a wrenching session and will post a picture. Thanks to Rick, I am sure Diaphragm Piston Bores sticking is my problem with number three. Any response to my spark plug colour pics, Ok, or not ?
    Eric
  26. plansea
    plansea Member
    Adjust screw here (yes, it was raining when I took this picture, the bike and I got very wet ! )
  27. RickCoMatic
    You might not see the slot of an Adjustment Screw.
    You might see a flat Plug with a dimple in the middle.
    To make your adjustments ... that Plug has to come out of there.
    Drill it a little bit right in the middle and be careful with the drill.
    Theres a SOFT BRASS Screw Head right on the other side of the Plug.
    You don't want to damage the Screw Slot with the drill.
    Drill it a little bit and then screw in a Drywall Screw.
    Grab the drywall screw with Vice Grips and extract that Plug.
    Now, you will be able to make Mixture Adjustments.
    Oil the Screw.
    Don't try and turn it with a regular screwdriver.
    Fabricate a screwdriver that fits the slot ... PERFECTLY.
    No end-play.
    Chances are, over time, the screw is stuck.
    Oil the hole and see if you can move the screw DOWN to good threads.
    If is moves ... exercise it back and forth ato lube the ultra fine threads.
    Once it moves without sticking ... fine-tuning begins.
  28. hman1169
    hman1169 New Member
    Western Mass
    Wow again! Thanks to the two of you! (plansea and RickCoMatic)
    I should have this carb problem licked by the end of the week...
    I have to go do my real job today, maybe I can get started tonight...
    Great pics, and Great Tips.
    I will definately share what I learn...
    (Rick- Sending a PM.)
