Let me see your seat!
Discussion in 'XJ Modifications' started by DianCecht, Jun 10, 2008.
  1. DianCecht
    DianCecht Member
    Central Illinois
    I was contemplating shaving down the stock seat in efforts to give the bike a lower profile... I don't want to do a solo seat (in respect for the wife), but I do want to shave it down a ways... do any of you have pictures of such an accomplishment so that I might make up my ever-wandering mind? Thanks again!
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I don't have any photos of my shved seats, but I've doen several of them. Every bike I've owned, I always pealed back the cover and took atleast an inch of foam off the front of the seat.
    It's fairly simple to do and looks factory if you do it right. All that is needed is a good sharp long serated knife to cut the foam. After cutting off and inch or so off the front of the seat, I use a 4" diegrinder to feather out the edges (make them round) and smooth the foam out before pulling the seat cover back on. You don't even have to completely remove the shole cover. Just peal it back far enough to expose the front half of the seat foam to cut it. It makes a nice step-seat. You will need to pull the cover tight and evenly on both sides and re-staple it to the seat pan then.
  3. stevetibb2000
    stevetibb2000 Member
    bakersfield
    look at my seat i shaved it down 2 inches and gave it a harley look kinda its in my gallery
  4. DianCecht
    DianCecht Member
    Central Illinois
    Thanks guys! That's a pretty good looking seat Steve... Did you keep the original cover or replace it? Looks sharp, I think we're going to have to give this a go.
  5. stevetibb2000
    bakersfield
    the orginal seat cover was riped and i put a leather-pleather faberic on if i ws you put a gel-insert in trust me it will help
