Removing and Installing Tires
Discussion in 'XJ Technical Chat' started by mrcarb, Jul 8, 2008.
  1. mrcarb
    mrcarb Member
    Can anyone offer tips as to what to set the wheel on when removing and installing tires? Two by fours?
  2. chadwickm
    chadwickm Member
    Wichita, Kansas
    Get yourself one of these: Portable Tire Changer, and one of these: MC Tire Changer Attachment. They pay for themselves changing just a single set over what a dealership would charge.
    I also suggest these for balancing: Dynabeads. I'm sure I will spark a heated discussion, but I've used these in three bikes now with excellent results.
  3. 85MaximXX
    85MaximXX Member
    S.W. michigan
    a 5 gallon bucket, I think a 50 gallon drum is too big but I haven't had one around to try it out. It always helps to have an extra set of hands.
  4. MiCarl
    If you look in my gallery you'll find pictures on a homemade unit, made with an old automotive wheel (Mine is from a truck), some rubber tube, threaded rod, scrap wood, nuts and washers. I think I spent about $10 on it.
    You'll need some tire irons and some method to break the bead.
    I have the Harbor Freight tire changer and am not too impressed with it. The bead breaker works ok. The MC tire adapter doesn't seem to hold the wheel firmly enough.
  5. chadwickm
    chadwickm Member
    Wichita, Kansas
    I had the same issue until I figured out that the 'lips' on the adjustable mounting points slip nicely on the rim and hold the wheel MUCH better than using the flat part. An old inner tube provided a lining as not to scratch the rim.
  6. Robert
    MrCarb, you can find a nice tutorial with pictures in our links. Just check out the XJ DITY section, second page.
    I've got the Harbor Freight setup and it works great. I also have a nice balancing stand but a cheap one can be made for under $30.
    If you run into problems, give me a shout. I'm usually home on weekends and would be happy to help you out.
  7. Polock
    a set of low saw horses, so your knee can get in on the last push and a extra set of hands
  8. mrcarb
    mrcarb Member
    Thanks to everyone for all of the tips!
  9. DianCecht
    DianCecht Member
    Central Illinois
    Tire Change Tutorial...
    I've always done it this way, and I've never had an issue banging up the rim. We used to do this to golf carts when I was a greenskeeper, and I've used the same method on bikes. You can look at similar information on balancing, or try out the dynabeads and make your own opinion on them.
