# 3 fouling
Discussion in 'XJ Technical Chat' started by figman, Jul 15, 2008.
  1. figman
    figman New Member
    North Carolina
    Replaced my old plugs with new ones. When I removed the old ones I noticed # 3 looked fouled. I replaced them and it was obvious # 3 was fouled, bike ran much better and after riding approximately 100 miles or so # 3 is fouled again. To diagnose where should I start.
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    You can check your petcock vacumm line for fuel. It may be drawing it into the intake if the diaphram has a hole in it.
    Or try moving your petcock vacumm line from #3 to another. Make sure you use the cap back on #3. See if your plug fouling moves.
    Or you may have a high float level on #3.
  3. RickCoMatic
    If the Plug was fouled ... the Bike would have not run smoothly.
    Unhook the vacuum line to the Petcock
    Place it to your lips
    Draw a vacuum line on that hose to see if you taste fuel
    If you do ... the Petcock needs servicing
    If you don't ... adjust the Pilot Mixture Screw for the Number-3 Carb Down a few degrees and see if that helps your situation.
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    the pros answer again.
    what they said^^ good luck
  5. figman
    figman New Member
    North Carolina
    I replaced the plug with one of the older ones and bike ran OK but I did notice some skipping at lower rpm's and as rpms raised the skipping ceased. I will check the vaccum line later today after work. I have cleaned fuel tank and checked petcock and noticed no fuel came from tank when in reserve or on position and when on prime fuel flowed. Thanks for your help. This is a very helpful site to a mechanically challenged individual as myself.
  6. figman
    figman New Member
    North Carolina
    Finally got the chance to to check the vacuum line to the petcock and as I drew on it I could hear air leaking. Investigated further and noticed the gasket between the vacuum line mounting block and the main body of the petcock had a small hole and is the source of the air leak. Should I replace the petcock or the gasket only. Thanks in advance for your help.
  7. switch263
    switch263 Member
    Austin, TX
    Get ahold of Chacal, he can sell you a petcock rebuild kit, or maybe just that gasket piece that you need. I used one of his kits on my petcock, works great, no more leaks!
  8. figman
    figman New Member
    North Carolina
    Appears that the cover caps for the pilot mixture screw have been removed. I oiled them and cleaned a little but I see no slot to insert screwdriver into. Any help would be appreciated.
  9. wizard
    Can you post a picture of a screw with no slot?
  10. figman
    figman New Member
    North Carolina
    I'll get the camera out tomorrow.
