Ideas on changing rear turn signals.
Discussion in 'XJ Technical Chat' started by dcbc991, Jul 20, 2008.
  1. dcbc991
    dcbc991 Member
    Rockford, IL
    Hi all. I'm not a big fan of the stock rear turn signals on my '85 Maxim. They stick out pretty far so I'd like to change them out to make the bike more streamlined. I'm curious what options are out there?
    I'd like to stay with the stock mounting location, don't want to drill out the rear fender or anything.
    Thanks for any suggestions.
  2. chadwickm
    chadwickm Member
    Wichita, Kansas
    So, your are wanting to keep your actual signals but shorten the stems?
  3. dcbc991
    dcbc991 Member
    Rockford, IL
    Well, I'd like to shorten the stems up to bring them in to the bike closer, but also find a new design for the signal itself...maybe something a little smaller in diameter. So I was wondering what others have done..if anything. I don't want to go anything wild...like flushmount or anything like that.
    Thanks.
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I switched mine out with a set from a FJ. They bolted right up only had to change the wire ends. They are more streamed lined not square and blucky.
  5. chadwickm
    chadwickm Member
    Wichita, Kansas
    Mine are still stock but I've had the same thought. I would be interested in what you finally decide.
  6. dcbc991
    dcbc991 Member
    Rockford, IL
    He lostboy, have a pic of your bike somewhere? I'd like to see how it turned out. From what year FJ did you get your hardware?
  7. lostboy
    The lights are aftermarket reproductions. I'm on the way out the door but i will try to get pic's later. Yes it had hareware.
  8. dcbc991
    dcbc991 Member
    Rockford, IL
    Saw a few photos of the FJ on the 'net with those signals. I like them alot better than the round style. Think I'll give it a try and let you know how it turned out.
  9. flash1259
    flash1259 Member
    W.R. Wisconsin
    www.ebay.com
  10. Ease
    Ease Member
    NL, Canada
    I first shortened the stalks on mine, then went with aftermarket (from e-bay, which the person above so gratiously linked for you). :wink:
    Shortened stalks:
    Aftermarket (ebay) lights:
  11. Ease
    Ease Member
    NL, Canada
    BTW there are more images / information inside my build page... And I have allready given the short stalk, stock mirrors away on this site for free. ;)
  12. lostboy
    dcbc991,
    Here are the photos of my bike.
  13. wizard
    i know what you mean about the stock indicators, i can't get on or off the bike without giving them a kick. maybe i'll go retractable!
