4500 and 5500 rpms
Discussion in 'XJ Technical Chat' started by oak450, Dec 21, 2008.
  1. oak450
    oak450 Member
    The foothills of Oregon
    The bike runs rough at these rpms. Feels maybe a little fuel starved, not sure. Combine this with low (I think) mpgs, wonder if my fuel mixture is off, or floats. But I'm not good enough to tell if its a fuel problem or some sort of issue with gears, rear drive, something.
  2. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Does it stumble at this RPM no matter what gear you are in?
    If so, I would want to know about valve clearances and carb cleaning and carb synch.
    One beauty of the carb synch bottles is that you can see carb balance while the motor is revving any any RPM.
  3. 82seca750
    82seca750 Member
    Greenville, TX
    i had this problem with my 750 seca and the carbs needed to be synched
