'80 xj 650 running badly when warm
Discussion in 'XJ Technical Chat' started by Mark1987, Oct 12, 2012.
  1. Mark1987
    Mark1987 New Member
    Had my xj for a moth or so now. It was in not the best shape when I got it. Cleaned about a sand pit full of sand out of the carbs and got it to run ok, the rubber boots from the carbs to the motor when completely split so yesterday I got them on and she runs beautiful when cold but once warm it starts to run badly. Seems like it is starving for fuel. Have not been home to check the plugs, on my way home from work ill leave the fuel petcock on prime that will eliminate the possibility of the vaccume diaphram not letting enough fuel in
    Any other suggestions for what could help? Or what the problem could be?
    I'll put some new plugs in next week as well and see what the coils are like
    Thanks for any help
  2. wwj750
    wwj750 Member
    central minnesota
    Classic symptom of out of spec valves. Check/Adjust valves & probably a carb clean/rebuild/sync.
    Cold start circuit (choke) may be not closing fully.
    Check air filter condition as well. Dont leave on prime without motor running. Might flood the crankcase with gas if the carbs need work.
    Good luck.
  3. bigfitz52
    Bingo. Start there. Get your valve clearances in spec, and do a compression test. Service and properly set up the carbs and you should be good to go.
    But start with the valves.
