81 xj550 maxim - cam sprocket/chain ?
Discussion in 'XJ Technical Chat' started by MJCXJ550, Mar 25, 2019.
  1. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    Assembling the top end and not sure if I have the correct chain to sprocket location. Manual says to pull the chain tight between the crank and exh/int cam sprocket them put the chain onto the sprocket. On the attached pic it shows how much slack I have above the top guide and I had to move the int. cam a little to get the bolt hole to line up. That made the int cam dot slightly to the right of the center on the cap. Am I on the right track or do I need to adjust to where the slack is between the int. Cam sprocket and crank sprocket side?
    I think you need to get 1/2 link over the sprocket to the cam chain tensioner side
    maybe a full link
  3. k-moe
    that's too slack on the top run.
    The chain should be touching the upper guide.
    All of the slack should be below the intake cam sprocket so the adjuster can take it up.
    chacal likes this.
  4. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    That worked...shifted the chain 1 link on the intake cam side.
    Franz, k-moe and XJ550H like this.
