81 xj650 side stand cut off in gear wiring query.
Discussion in 'XJ Technical Chat' started by mervyn, May 22, 2014.
  1. mervyn
    mervyn New Member
    south africa durban
    Hi , Does the 81 xj650 have a kill switch if side stand is dpwn when putting into gear with motor running and if so where is it?
    Also where about will I find the neutral light wiring .Bulb is ok but no light comes on.
    Thx
    Merv
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    the side stand relay is tied into the side stand itself. it may need cleaning. your bike should shut off if the side stand is down and you shift from neutral. the neutral switch connects into the clutch handle similar to the way the rear brake switch connects to the front brake handle.
    Gary
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    there's no separate "kill" switch, the side stand switch, neutral switch and clutch switch, work in conjunction with each other via the safety relay, to do exactly as you say.
    side stand switch is on same frame bracket as the side stand
    neutral switch, should be behind shifter cover
    clutch switch is under clutch lever
    safety relay, dunno for sure but maybe under tank, near flasher relay
    stu
  4. mervyn
    mervyn New Member
    south africa durban
    Thanks for your prompt replies . Will lie down on floor and search tomorrow.
    Merv
  5. bigfitz52
    I love this. It's like the old proverb about the group of blind men and the elephant.
    Guys, NOT ALL XJs ARE IDENTICAL!
    The sidestand switch is on the sidestand bracket on the 550/600s; but on some of the shaft-driven bikes it's tucked away under the case.
    Not ALL models have a separate sidestand relay; some just have the switch but the overall operation is essentially the same.
    The "kill" switch is that big "OFF/RUN/OFF" switch on the RH handlebar pod.
    The safety relay also tends to be located slightly differently between models.
  6. rocs82650
    Middle Tennessee
    Fitz,
    blind...how so? iirc not much difference from '81 to '82 for what he asked. I could be wrong.
    Gary
  7. mervyn
    mervyn New Member
    south africa durban
    thanks guys
    merv
  8. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
  9. mervyn
    mervyn New Member
    south africa durban
    To Gary, bigfitz and others...,thx for the site info of Chacal's wiring forum. The guy's a genius and I hope he doesnt have to do his own typing.
    Lots of studying and learning still left on the xj650 for me to conquer.
    Back to lying on my back on a cold concrete floor to sort problems out(lol)
    Gonna make 1 good bike out of the 2 i got.
    thx
    mervyn
  10. bigfitz52
    But he's not in the 'States. His '81 XJ650 is more akin to our '82 Seca 650 than to the '81/'82 Maxims sold here.
  11. rocs82650
    Middle Tennessee
    cool. I stand corrected and I apologize.
    Gary
