'82 750 Maxim Battery Sensor
Discussion in 'XJ Technical Chat' started by luminaman, Jul 19, 2008.
  1. luminaman
    luminaman Member
    Clive, IA
    :?: My '82 750 Maxim is missing its battery sensor, so the red warning light on the console flashes continually. I've heard I can "fool" the system by installing a resistor between the battery and light. Has anyone ever done this, and if so, how? Would it be easier to try to find a replacement sensor?
  2. toastturbo
    toastturbo New Member
    Just tap into a hot wire, like the tail light or positive on battery. Problem solved.
  3. randall68
    randall68 Member
    Ditto...i put mine to the pos battery and it went away!
  4. luminaman
    luminaman Member
    Clive, IA
    Forgive my confusion. Do I;
    (1) insert resistor into a length of wire
    (2) attached one end of wire to positive terminal of battery
    (3) attach other end of wire to harness
    Is that the procedure?
  5. Nick
    Nick Member
    Vernon, BC Canada
    Depends on who you talk to!
    You can do a search on this site for battery sensor and read a lot of suggestions.
    Here's a couple of links on the subject.....
    http://pw1.netcom.com/~rvtucker/battwarn.htm
    http://www.xjbikes.com/Forums/viewtopic/t=6162.html
  6. maz43
    maz43 Member
    Detroit area
    I had the same question.
    After reading several solutions on this forum I never saw the light again.
    I have a sensor but chose to connect the wire to a 12 volt source with juice when the ignition key is on. No diodes, no over voltage or problems.
