82 seca 750 how 2 bypass the headlight warning indicator ?
Discussion in 'XJ Technical Chat' started by JayEye, Jun 11, 2010.
  1. JayEye
    JayEye Member
    Chicago Heights, Il
    Good morning all,
    Yesterday i upgraded my older dual element xenon bulb to a true bi xenon bulb & here's my problem. With the dual element 1 the xenon was the low beam & it had a H3 as the high beam. The h3 close the head circuit and i had to change the head wiring, swapping high for low & low for high then i was good to go with no warning indicator. The new bulb does not have a secondary h3 bulb to close the circuit. The cool part about the new bulb is that it gives me hi & low beam xenon light with a sliding reflector.
    Now the question, what is needed for me to make the system check think it is in a close state?
  2. JayEye
    JayEye Member
    Chicago Heights, Il
    bump.... any input??
