82 seca 750 yics
Discussion in 'XJ Technical Chat' started by bridan, Aug 3, 2008.
  1. bridan
    bridan New Member
    there are three white wires coming off of the stater, if you follow the up to
    a plastic connection . my problem is that the clip someone has clip the connection off.. why i don't know. from the stater side and i don't know what wires go where don't want to fry something up so i thought i would ask
    ty in advance
    brian
  2. cturek
    cturek Member
    O'Fallon, MO
    The three wires continue on past your removed 3 conductor connector and on to a larger connector. If you don't have a wiring diagram, I can email you a diagram in pdf format. Keep in mind that the diagrams are known to have some errors. PM me if you want the file.
  3. bridan
    bridan New Member
    do they a special order that they are connected or are they just a through?
    i guess what i'm asking is dose it matter which wire go where?
  4. MiCarl
    The three white wires from the stator hook to the three white wires in the wiring harness. Order doesn't matter.
    Someone probably clipped the connector because it overheated and burned up. A common problem.
