82 Seca RJ main jet needle question
Discussion in 'XJ Technical Chat' started by paulg, Apr 15, 2008.
  1. paulg
    paulg New Member
    British COlumbia
    Hi, I'm new to the forums. Bought an '82 Seca last fall. It was supposed
    to have had the carbs cleaned in a local shop but ran rough. I pulled the
    carbs and cleaned them carefully with a spray type cleaner , tooth brush
    etc. and air. When I started it up it idled at ~ 3000 rpm when it warmed
    up. Have the carbs off again and have noticed the main jet needle on two
    of the carbs sits lower than the other two. There doesn't seem to be a way
    of setting this like on old SU's, Mikunis or Amals. Has anyone else seen this
    and if so, what's the fix?
    Tnx in advance --paul , Delta BC Canada
  2. chacal
    Hey Paul---the needles on the Hitachis are non-adjustable, as you probably know. HOWEVER, the stepped round plastic "head" of the needles can actually move a bit up and down the needle shaft, you just have to press down on them to get them to "seat" against the bottom edge of the top of the needle (if that makes any sense). The top of the plastic head should be almost FLUSH with the top of the needle, with the aluminum needle head (with the straight slot in it, looks like it's a screw up there but it isn't!) just peeking out above the top surface of the plastic head (the head is technically called a "spring seat" by Hitachi, but what do they know?).
  3. paulg
    paulg New Member
    British COlumbia
    Tnx Chacal, one of the needles is as you say , the others are buried way
    down in the spring seat. I'll try and move the needle, carefully!!!
    ---p
  4. chacal
    Sometimes you have to "pound" (by hand) the plastic seat back "down" onto the needle shaft. I take the needle, upside down, and pound the plastic head down against a flat, hard surface (countertop, etc.) and that can get them back in place. They are on there pretty tight!
  5. paulg
    paulg New Member
    British COlumbia
    Chacal, I popped the three down that were low, now all lined
    up. I'll check everything else and put them back together, see
    how she runs. Methinks I'll be checking a lot of other things that
    the previous owner had done!!
    Again tnx for the info
    Cheers ---p
  6. chacal
    NOW you're methinking really well..............!
