82 xj 650; Best solution for a better seat?
Discussion in 'Hangout Lounge' started by seamastertime, Feb 23, 2009.
  1. seamastertime
    seamastertime New Member
    Refurbing an 82 xj650 and would like to know if there is a good source for a more plush/cool seat. Or should I take the stock seat to a reapholster shop? I saw J.C. Whitney has an ok looking one for pretty cheap.... I keep seeing xj's with cool seats in pics but can't figure out where folks are getting them....
  2. bigfitz52
  3. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    SeaMaster,
    I have pondered this same question and spent many hours carving seats up and adding memory foam here and high density foam there, low density here. Anyway, the big problem that I've found is the riding position more than the seat its self. The angle of the back, hips, and knees is what causes me so much fatigue. I do have many underlying musculoskeletal issues that adds to problem but that aside, I have basically created a solo seat that serves me pretty well but still needs alittle more work. The down side of that is it limits the size of my passengers. That may be an upside for some.
  4. Hack
    Hack Member
    Ontario, Canada
    Sargent cycle did a nice job on Bigfitz's seat. Another option I found one night while cruising the net is Saddlemen. They make kits to recover your seat with new foam, and even have complete seats with new pans. Not cheap, but available.
    I've wondered about their bucket seats and whether or not they are more comfortable than the stock seat for longer trips.
    Here's a link:
    Saddlemen
  5. bigfitz52
    When I send the seat from my '83 to Sargent's I'm going to have them "fill" what little step there is so I have a nice long flat seat. The ability to move around and change ridng positions is paramount to comfort on long rides or when traveling, at least for my 6'5" frame.
  6. sushi_biker
    sushi_biker Member
    Uh, I plugged 1982 Yamaha XJ750 into their search engine and came back with "No product matches your search criteria".
  7. Hack
    Hack Member
    Ontario, Canada
    I just tried it and got results for Secas and Maxims...
  8. sushi_biker
    sushi_biker Member
    What did you type?
  9. sushi_biker
    sushi_biker Member
    Ne'er mind. I widened the page and found another "search" button way off to the right. I found them.
  10. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I've got the seat from a Sportster on mine. It fit perfect and looks pretty good too.
  11. b0Rn2bL8
    b0Rn2bL8 New Member
    SF East Bay, CA
    PainterD,
    how did you mount it?
  12. flash1259
    flash1259 Member
    W.R. Wisconsin
    Painterd
    that is one sweet ride there. I can only hope mine looks as good as that when I get done.
  13. Great_Buffalo
    I bought one of the saddleman seats off an inmate here but it was worse, for me, than the OEM seat. It pushed me way too far forward so the back, hip, kne angle was even worse.
    If anyone needs a cover for the saddleman touring seat I have one that only has about 200 miles of butt time on it. I used the foam form to create what i'm using now.
    I am going to go to one of the custom shops that I use for some service and see if I can do something similar to what PainterD did. He has a slew of different seats that I'm going to dry fit on my bike and see if there is one that would work with minimal fabrication.
    The Buff
  14. PainterD
    Born2bla8,
    The Sportster seat has a large groove in in the front of the seat pan, so I just made a short flat piece of aluminum the same width that's bolted using the rear tank mounting bolt. The seat just slides onto the aluminum tab and is bolted down to the fender in the rear. It rests on the frame rails like it was made for the bike.
    There are alot of seats from other bikes that make good solo seats for these bike on Ebay. The Honda Shadow seats fit pretty well and are very comfortable. Most of the V-twin cruisers have two-piece seats, so you don't have to use the rear portion if you want a solo seat.
