82' XJ650 Smoking
Discussion in 'XJ Technical Chat' started by DriftRacer23, Aug 11, 2014.
  1. DriftRacer23
    DriftRacer23 New Member
    New York
    Hello, the other day I went to start my maxim on a slope and it back fired through the carbs and was putting out a grayish white smoke. The smoke was coming from my air-box if that helps. After this happened I found that the bike didn't want to start and when it did it wouldn't idle. Seeing as I had these problems I put the bike up and haven't touched it yet.
    I was wondering if I should be concerned about this and what might have been damaged, or if I'm just worried for nothing.
  2. hogfiddles
    You flooded the carbs and airbox that's all. Just in case a float got stuck, though, opens the oil filler cap and take a sniff. Smell just like old oil? Good. Smell like gas? Drain it and replace the thinned out oil. Otherwise you'll overheat or blowup ....... Or both.
  3. DriftRacer23
    New York
    Thanks, I just emailed you. Sorry it took me so long to reply back to you. I've been moving lately.
