82 XJ750 High Idle
Discussion in 'XJ Technical Chat' started by LeClairerog, May 12, 2017.
  1. LeClairerog
    LeClairerog 1982 XJ 750 Maxim
    LeClaire, IA
    1982 XJ750 J Maxim
    I recently had a local shop clean the jets in the carburetors.
    The bike now has a very high idle (2800-3000 rpm). I don't see that either of my service manuals addresses the issue. However I notice there is a set screw under the left side of the tank behind the carb.
    If I make adjustments to this screw will this address my high idle issue?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    How did the shop clean your jets? Did they do a full tear down of the rack and carbs?
    Did you take the bike to them or just the rack?
    When was the last time th carbs were at Church?
    I know not of 750's nor the set screw you speak of . . .
    Unless you are referencing the adjustment screw that is inbetween carbs 2 & 3. Yes, that will change your idle, but honestly there could be a lot more going on. Try turning that knob and see if the idle speed changes.
  3. Rooster53
    You can try that, but be aware that most shops do not do an adequate job on the carburetors. Or, check these carbs out, now available from Len at XJ4ever. You can see the knurled idle adjustment knob on the back.
    Did you get the battery warning squared away?
    LeClairerog likes this.
  4. LeClairerog
    LeClaire, IA
    Yep, battery is taken care of. I think I may have a vacuum leak. I'm going to check that after I try to adjust the setting on the setscrew.
    I truly do not now. My intention is to break them down this winter and go through them thoroughly. Church of clean.
  5. LeClairerog
    LeClaire, IA
    I'm sure it was not a thorough cleaning. His price was way too low for that. He said they put it into an ultrasonic cleaner, and I'm wondering if it was just the Jets. I don't know a lot about carburetors, but I have a feeling I'm going to learn. This coming winter I'll pull them off and go completely through them. Church of clean thoroughly. I have another bike to ride, but I really enjoy writing this one.
  6. k-moe
    My bet is that the whole rack was dipped. You now have useless throttle shaft seals. You can't wait until winter to break the rack if that's what happened.
    Do not ride it with the high idle. Damage to you, the engine, or both will result.
    Jetfixer and LeClairerog like this.
  7. LeClairerog
    LeClaire, IA
    I'll call and find out. If that's the case Chacal gave me an email to send them to you to get them rebuilt.
    I have another bike to ride. So it's not like I will have withdrawals.
    Rooster53 likes this.
  8. k-moe
    He better not have. That would make Hogfiddles angry :p
    While I can rebuild carbs, I don't have any time to do so for anyone else for another year or so.
    Stumplifter likes this.
  9. LeClairerog
    LeClaire, IA
    Verbal command. He gave me an email of an individual who can handle the task. I'd do it but my 10 % failure rate has made me risk averse and a procrastinator.
    Hogfiddles is the contact.
  10. hogfiddles
    That would be me :)
  11. LeClairerog
    LeClaire, IA
    Thanks. I'll get in contact with you soon.
    Jetfixer likes this.
  12. LeClairerog
    LeClaire, IA
    Stumplifter, I trailered the bike and took it to them. I purchased the bike two years ago and have been fixing one thing after the other since then. Believe it or not, I bought it from my sister in Tomahawk, WI. She told me it was well maintained. I'm still waiting for her definition on that term.
  13. k-moe
    Even a well maintained machine will have things that need to be addresss if left to sit for a few years, and other things that need done simply because some parts have aged beyond their use-by date (like throtttle shaft seals, float needles, brake lines, etc.).
  14. Stumplifter
    near Irma, WI
    I worked at the Harley plant on Somo Avenue in Tomahawk two winters ago . . . . Tomahawk is a nice town just 15 minutes north of me.
    Kmoe may be right, they probably just dipped the carbs, to get things right you need to go to Church and replace all this old tired rubber bits. Or have Dave do them - rumor has it he knows a thing or two. ;)
  15. LeClairerog
    LeClaire, IA
    Maintenance is the key.
    thanks for the recommendation. I'm going to take it. My sister and her husband live on Lake Nokomis.
