82 xj750 No response to ignition
Discussion in 'XJ Technical Chat' started by FetusChrist, May 4, 2016.
  1. FetusChrist
    FetusChrist New Member
    Utah
    Speedometer wasn't working so I found one at the junkyard I liked.
    A bit of trial and error and using one box out of the old cluster and I got it all working. The four lights tachometer backlight and even the speedometer was working. Then I got home from that test ride and turned it off and that was the last of it. Any idea what I could have messed up? And is there a way to wire up the headlight without going through the old instrument cluster?
  2. Jetfixer
    Check fuses, grounds , battery voltage would be where I'd start (no pun intended lol )
  3. Chance
    Chance Member
    Rockland, Ontario, Canada
    Does it turn over, if not, give your starter solenoid a tap while pushing the start button and if it turns over it's you solenoid. (I had this problem recently on my 550maxim)
    82madmax likes this.
  4. Jetfixer
    What he said ^^^^
    Chance likes this.
  5. 82madmax
    82madmax New Member
    SFSD
    We had that issue on my 82 xj750 we switched from the stock ignition to a push button my guy said something about running different voltage or some shit
  6. k-moe
    Did you follow the instructions in the ATARI Delete thread? You can't just swap the gauges and wire the lights. The systems monitor has to be bypassed correctly.
  7. 82madmax
    82madmax New Member
    SFSD
    Which are you responding to?
  8. k-moe
    The OP.
  9. FetusChrist
    Utah
    Battery is still strong and checked the fuses they seem good, but it's still the old glass tubes so I guess I'm done putting off switching those to blades to be sure. Total bike noob and even worse at electrical. How do I go about checking grounds?
    As for the atari delete I'm a bit timid to start cutting just yet. The colors of the wires at the plugs seem to be different on my bike. Should I go ahead and follow by color or by location at the plug?
  10. k-moe
    The colors may be faded, but they aren't different.
    DrewUth likes this.
  11. DrewUth
    DrewUth Active Member
    South Jersey
    We're all a little faded...:rolleyes:
  12. Chance
    Chance Member
    I thought that was Jaded...:D
    Yardawg likes this.
  13. FetusChrist
    Utah
    So I've done the atari delete and have new fuses installed. Still nothing. No headlight no instrument lighting, no turn signals no neutral light. Nothing. Might as well have the battery out, the results would be the same. I'm pretty stumped here.
  14. FetusChrist
    Utah
    Whelp I got it after some fiddling around. I had a short I didn't catch.
  15. Chance
    Chance Member
    Glad to hear you got it running!
