83 XJ internal engine issues????
Discussion in 'XJ Technical Chat' started by katikyoo, Mar 22, 2010.
  1. katikyoo
    katikyoo New Member
    My xj 650 never ran right, cleaned the carbs and went to synce up carbs from vaccum ports and found some compression along with the vaccum. i checked my valve clearances. And from what i can gather here they werent far enough out of spec to hold the intake valve open. Should i pull the head off and check for burnt valve seats?
  2. skippy344
    skippy344 Member
    Aggieland, TX
    Let's check the timing first. Gotta make sure the cams are opening and closing at the correct time.
  3. mlew
    mlew Well-Known Member
    Apex, NC
    Do a compression test before you take anything apart. Let us know what the numbers are.
  4. katikyoo
    katikyoo New Member
    I Checked The Valve clearances and compression. Compression was between 30 and 40 for all cylinders. Intake valve clearance was .000, .004, .002, .002
    Exhaust valve clearance was .005, .007, .004, .007
  5. katikyoo
    katikyoo New Member
    I also checked timing and it is within spec.
  6. Robert
    Whoa! 30-40 PSI? You have major problems in there. Your clearances are a mess. 0.004-0.006 for intake, 0.006-0.008 for exhaust. You need to get the valve specs within tolerance before your compression test will give you values worth anything.
    Good luck amigo!
