83 xj750mk questions
Discussion in 'XJ Technical Chat' started by biggyfaction, Feb 27, 2013.
  1. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    I just joined this site. Last week i bought a 1983 xj750mk midnight maxim with a full touring package. i'm having troubles finding parts for it. i think i need new coils. ive checked for spark and it looks weak. ive seen ads for aftermarket dayna coils anyone know anything about them? im a taller/larger guy and im loooking to get forward controls for it and needed ideas. i cant afford much. this will be my first season as long as i can get it running right.
      File size:
      17.9 KB
      1,076
      File size:
      20.2 KB
      1,076
      File size:
      17.3 KB
      1,076
      File size:
      19.7 KB
      1,075
      File size:
      17.3 KB
      1,076
  2. RickCoMatic
    Dyna Coils would be a great upgrade.
    Get the Mounting Kit to make installing them a breeze.
    PM forum member - chacal for further info.
    Click on XJ4Ever Logo
    (top of page)
  3. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    do you know where or how i can get/make forword controls?
  4. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    I popped in a new battery and that solved the spark issue. still wont fire though. needing warmer weather to check the petcock and the carbs.
  5. bleedblue4life
    bleedblue4life New Member
    Ohio
    I like that touring setup!
  6. RickCoMatic
    If you HAVE good Spark, ... it narrows-down what to look for.
    Do a "Pop / No Pop" Test.
    Shoot some Starting Fluid into the Airbox.
    Try it.
    If she "Pops" ... Its Fuel Supply or Cold Weather related.
    If Starting Fluid will get it Started, ... its the cold.
    If it runs a second and dies, ...
    You have a Fuel Delivery issue.
  7. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    im thinking about selling them so i can make a custom xj. i havnt seen anyone else with the quick detach bags
  8. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    i live in Iowa (USA). it is cold here right now. even with starting fluid i cant get it to pop off
  9. RickCoMatic
    Well, ...
    IF you got Spark.
    There's just AIR and FUEL to check-out.
    Starting Fluid got you nothing.
    So, lets check the possibility it ain't getting enough Air.
    Check the Airbox for Rodents, evidence of former rodents, nesting materials, bees nests, hidden dope stashes or a ridiculously filthy Air Filter.
    IF the Airbox ain't it, ... we go to Square One.
    Compression Test!
    The results will either set your mind at-ease, or break your heart!
  10. MiGhost
    MiGhost Well-Known Member
    I have the deluxe tour package on my midnight also. If you are at all serious about selling yours. Send me a PM with your price.
    Ghost
  11. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    heres an update. air boots are shot. got it to pop with starting fluid. petcock is functioning perfectly in all 3 positions. crack in the vacuum line. i got new gas lines for both to the tank. pulled the carbs out and opened the drains 1/3/4 had fuel and 2 had none. going to open them up with a help on here to figure out whats wrong. local shop has a used set of boots off an old bike that are still in god condition. they're asking $35 is that too much for all 4? did a compression test today and got 120-125 on all 4 cylinders
  12. k-moe
    That's not a bad price for 4 used boots....if they don't have any cracks.
  13. RickCoMatic
    Probe the #2 Drain with a long darning needle and see if the Bowl Drainn is clogged.
    I agree, 35-Bucks is a real good deal on Manifolds.
    Exercise great caution removing the old Manifolds.
    The fasteners are prone to seize (cold-weld).
    The Fastener will turn as if it is loosening, but the Cap Screw is actually TWISTING until it snaps.
    Good Luck.
    Be careful.
  14. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    im working on the carbs right now. tiny bits of paint and rust in them got a full cleaning on my hand. the last owner had someone "rebuild" them last fall. opened them up and o-rings on the tubes are bad. and alot of screws that where almost stripped out. i got them all out. ill let you know how it turns out when i finish putting them back together
  15. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    the air boots are in great shape. no cracks and they move easily no wear marks except where clamps sit
  16. bleedblue4life
    Ohio
    I'd love to have that touring kit but I doubt it would bolt up to my 650. Plus trying to ship it would be quite a hassle.
