83 xj750mk top end questions
Discussion in 'XJ Technical Chat' started by biggyfaction, Feb 24, 2014.
  1. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    I have a leaking head gasket. ive cleaned the area and tried to run it. it barely keeps compression on 1. i have a new top end kit. i need to know how many rubber pressure washers are needed for the valve cover. i found a kit with 4 inner and 8 outer rubbers. im also looking for tips on how to do this correctly the first time. i just want to make sure i get everything lined up before i remove the cams.
