84 XJ600 engine into an 81 XJ550 frame?
Discussion in 'XJ Technical Chat' started by BonezOz, Sep 11, 2011.
  1. BonezOz
    BonezOz New Member
    Sydney, Australia
  2. TIMEtoRIDE
    A resounding "yes". You'll need to use the 600 carbs and ignition box.
    check it out
    He ends up building a 600 motor /\
  3. BonezOz
    BonezOz New Member
    Sydney, Australia
    I thought as much and after I got it home yesterday I definately felt that it would, but I had a MC mechanic tell me last week that there was no possible way.
    Cheers
  4. bigfitz52
    Horse feathers. Oh, sorry--- EQUINE PLUMAGE!
    The 550 and the early 600s were virtually IDENTICAL; we've got members on the site with XJ/FJ600 motors in Seca 550 frames.
    Just be sure it's an early 600; not the later (Diversion/Seca II) motor; the cylinders are tipped forward on those later generation motors and they WON'T fit. If it's got the exact-same shaped clutch housing and primary sprocket covers, it's the right lineage 600 and it will drop right in. Be sure to use the TCI unit from the 600.
    If I ever blow up my '83 550 Seca I'll be looking to replace it with a 600cc mill.
  5. Ledicott96
    Ledicott96 Member
    North west England
  6. Kickaha
    New Zealand
  7. Ledicott96
    Ledicott96 Member
    North west England
    Right thanks for that.
    Al
  8. inet101
    inet101 Member
    http://www.ebay.co.uk/itm/Modified-1981 ... 336ba78c3b
    Wow....would luv to throw a leg over this one! Not too far off the direction my 550 is headed cept his has much more shine.........
    As for the 600/550 swap....its a straight away bolt in cept for the black box as noted . I have a 82 Seca (US spec 550) and both a extra 81 550 & a 86 Radian 600 lump. Had em both installed for fitting up, no probs what so ever.
  9. BonezOz
    BonezOz New Member
    Sydney, Australia
    Uh Oh, shaggy, I think I remember seeing a burned out section of that particular box.... :(
  10. dinoracer
    dinoracer Member
    Chattanooga, TN
    You don't need a different black box, you can use the seca 550 black box.
    They have the same connectors as the seca's so why wouldnt they work? Besides I have a FZ 600 motor in my seca 550 using stock ignition.
    Sean
  11. a100man
    a100man Well-Known Member
    Bedford, UK
    Old thread I know - but has anyone figured out a solution for connecting 52mm (XJ600) carb mouths back to the stock 550 (Seca) airbox ?
    Cheers
  12. bigfitz52
    Couldn't you use the boots from the 600 and "adjust" the holes in the airbox accordingly?
    How different are the airboxes themselves? With the motor out, the airbox just slots in; will the 600's box fit in the frame the same? I can't check the fiche, we didn't get the actual XJ600 here.
    Interesting side note, something I noticed in the FJ600 fiche: Instead of capping off the vac ports on the intake manifolds, #2 and #3 are connected via a vac line; and #1 and #4 are "teed" together, the tail of the "T" runs to the petcock.
  13. a100man
    Bedford, UK
    Hi BF
    Indeed that was likely to be my first move - just wondered if anyone had been there before me.
    Presumabely the intake links are some kind of 'balancer'...
    Cheers
    JS
