85 Maxim X, It doesn't turn off
Discussion in 'XJ Technical Chat' started by jonhohlf, Jun 8, 2020.
  1. jonhohlf
    jonhohlf New Member
    La Crosse, WI
    My 85 Maxim X doesn't turn off when the key is switched off, the engine stays running. The tail light does shut off. Has anyone else experienced this before. Looking for pointers before I start digging into it.
    Jon
  2. xHondaHack
    Orange CT
    Jon,
    Actually had the same issue on mine a few years back. Turned out to be the wires melted together at the connector for the ignition switch. Pulling the fuses did not help because I found the feed wire to the switch (red) was feeding the brown wire that supposed to power up everything with the key on. You can pull the main fuse but then can't run the bike.
    Remove the headlight and look through the "rats nest" of wiring and find that three pin connector (red,brown and blue wires). See if there's an issue there and get back to us.
    Tony
  3. jonhohlf
    jonhohlf New Member
    La Crosse, WI
    Thanks Tony, I will check that out.
  4. jonhohlf
    jonhohlf New Member
    La Crosse, WI
    Thank you again Tony, the 3 pin plug itself was melted and fused the connectors together, found the problem in the first place I looked with your help!
    Jon
  5. xHondaHack
    Orange CT
    Well lots of current going through that connector and if it gets corroded, creates a high resistance point, then heats up and melts.
    This looks like a good source for the original style connector/terminals that you could replace it with:
    http://www.cycleterminal.com/250-connectors.html#SC250
    Tony
