85 xj700 maxim wiring diagram
Discussion in 'XJ Technical Chat' started by rg700max, Sep 26, 2010.
  1. rg700max
    rg700max New Member
    Could someone post a website link for a wire diagram/schematic for my 85 xj700 maxim. I have looked everywhere I can think of. Any good website would be GREATLY appreciated.
  2. jonrms
    jonrms Member
    England Uk
    I do have it... I will have to scan it for you... as I cant upload it for some reason being adobe.... ARRRGH... It is the full wiring diagrham that I looked for ages for!!!
  3. jonrms
    jonrms Member
    England Uk
  4. Gadget
    Gadget New Member
    Glasgow SCOTLAND
    Been looking for this my self with no luck Thanks a lot. :D
    Ian
  5. jonrms
    jonrms Member
    England Uk
    Your welcome Gadget... I am in england.. but from america... so give me a shout... we might meet up at kelso next year or before... although with this weather atm its not likely..
  6. jonrms
    jonrms Member
    England Uk
    just a thought.. mods might want to make that link a sticky!!!! wink wink .. hint hint..
  7. rg700max
    rg700max New Member
    Thanks a ton for the scan, it will be a huge part of getting the project up and running!
  8. jonrms
    jonrms Member
    England Uk
    your welcome... bud... it was a pain in the a55 to locate!!!
  9. rg700max
    rg700max New Member
    Yeah I checked just about everywhere I could think of online. On the bright side, got her turning over last nite, thanks to your schematic. Picking up a TCI unit tomorrow and should have spark.....and with any luck a running engine. Thanks again
  10. jonrms
    jonrms Member
    England Uk
    if your in the uk give me a shout .. I will help anyway I can.
    or next time I go back home (to america) i will gladly help. :D
    good luck and get some pictures up please bud.
  11. jonrms
    jonrms Member
    England Uk
  12. to the max
    to the max Member
    Akron, Ohio
    is the diagram for the x the same as the n?
  13. XJ550H
    no it is not
  14. XJ550H
  15. to the max
    to the max Member
    Akron, Ohio
    i just got an 86 xj700n. this is my first bike. it was last tagged in '08. i'm guessing it's been 10 yrs since it ran last. i was told they used to clutch start it because it wouldn't start from the switch. i'm guessing at some point it wouldn't start at all. it had 2.5 qts of oil in it. didn't find any bits of metal in the filter or drain pan.
    first thing i want to do is get the starter circuit working.
    any suggestions on where to get parts? need an o-ring for the filter screw and a filter right now
  16. XJ550H
    our supporting vendor has the o rings www.xj4ever.com Info@xj4ever.com is Lens email , he is aka chacal on the forums.
    some filters come with the filter cover o ring but it is not always the correct size. xj4ever has the correct sizes .
    did you find the spring and washer behind the filter ? washer may be stuck to the filter. critical parts.
    for the starter switch open up the control and clean the starter button contacts, use electrical contact spray cleaner. then smear with some dielectric grease
    you should start your own thread in the tech forums put bike model and year in title your name or problem and we can follow what problems you have and what work you have done.
    ie to the max's 86 700n starter.
    then post all your questions there even if they are not starter related
    not starting at switch could be dirty switch ,failed/ditrty ground.
    maybe you have a bad solenoid.
    start a thread and we will move forward on how to get the starting system working
  17. to the max
    to the max Member
    Akron, Ohio
    thank you. glad there are enthusiasts like yourself to get help from.
