85 xj700x carb problem
Discussion in 'XJ Technical Chat' started by Gcxcountrystar1, Sep 14, 2016.
  1. Gcxcountrystar1
    Gcxcountrystar1 Member
    Hartford, IL 62048
    I was riding yesterday came to a stop and if you are sitting on the bike the far left carb just flooded Gas all over. So I thought that the fuel bowl gasket blew I removed the carb today and the gasket looks fine. I don't know what to do
    that would likely be a stuck float needle valve assembly.
    another possibility would be a leaky vacuum hose but only if it is hooked to the same carb. left side when sitting on bike is #1
  3. Gcxcountrystar1
    Hartford, IL 62048
    I just threw the carb on and the carb is leaking from a black nipple between carb 1 and carb 2
  4. XJ550H
    i belive that the nipple is an overflow connection
  5. xHondaHack
    Orange CT
    Yes that's a T fitting that the overflow hose is supposed to be connected to.
    You have a float that is stuck open. Tap on the float bowl of both the #1 and #2 carbs with the handle of a large screwdriver to see if you can get it to free up. Hopefully that will keep it from flooding gas all over. However, I would plan on immediately replacing all 4 float valves and be sure to do an oil and filter change for good measure.
    If gas is flowing with the bike off, you should also rebuild the petcock valve.
    Tony
