85 xj700x project
Discussion in 'XJ Modifications' started by Woje, Oct 26, 2015.
  1. Woje
    Woje Member
    48915, Lansing, MI
    Picked up a few months back
    New bars
    lowered rear
    plan on trimming down the seat and re upholstering myself
    Turn signals will be taken off and smaller ones to come
    Tach is busted so I'm either replacing with stock or going to a single all digital
    Anyone with rear fender ideas I need some help I want to keep this a two seater so cutting off the rear of the frame is not likely but the original is square and the rear tail light is hideous IMAG0482.jpg IMAG0707.jpg IMAG0711.jpg IMAG0708.jpg
  2. Woje
    Woje Member
    48915, Lansing, MI
    Finished the seat today turned out pretty good I'll work on the passenger seat and sissy bar later this week IMAG0754.jpg
    CasingNinja likes this.
  3. Nederlander
    Nederlander New Member
    St. Paul, MN
    What length rear shocks did you end up using?
  4. hogfiddles
    Smaller turn signals? Is that so you're even less visible?
  5. strat
    strat Member
    Williamsport, PA
    I have smaller signals on my bike that are brighter than the factory signals...
    Woje likes this.
  6. Woje
    Woje Member
    48915, Lansing, MI
    it's because I feel like it next question
  7. Woje
    Woje Member
    48915, Lansing, MI
    I got some help from strat on the rear shocks my last bike was a Suzuki ls650 after reading he used the savage shocks I found a set on eBay used for $35.00 I believe 10.5 inches 2 shorter than stock fit real nice
  8. Woje
    Woje Member
    48915, Lansing, MI
    Jetfixer and k-moe like this.
  9. CasingNinja
    CasingNinja Member
    AZ
    Did you use the stock seat pan and cut it down? I'd really like to do something similar to the seat on my 85 XJ700X.
  10. CasingNinja
    CasingNinja Member
    AZ
  11. k-moe
    Big lights make you visible. Being visible helps prevent the leading cause of hospital trips; "But officer, I didn't see him."
    There are other options, but surface area is just as important as brightness, so don't go too small.
  12. hogfiddles
    Size matters
  13. Woje
    Woje Member
    48915, Lansing, MI
    yes original cut it with dremel spray adhesive memory foam some staples and an old leatheer jacket
  14. CasingNinja
    CasingNinja Member
    AZ
    Here's my seat. My first time and it shows. I am happy with the size and shape, but I bought inexpensive material as I expected to mess up. And I didn't realize the staples would be noticable until after the pic.
  15. Woje
    Woje Member
    48915, Lansing, MI
    Nice just leave the material longer place your staples as far under the seat then trim make sure to pull tight the whole time
  16. CasingNinja
    CasingNinja Member
    AZ
    Thank you for the advice! I ordered the material to redo the seat, I will post pic when it's done.
    Thanks again!
  17. Woje
    Woje Member
    48915, Lansing, MI
    Finished the seats the gauges need a little cleaning up so I took them off to paint I like the look without them anyone know how to get this thing started without the gauges connected
  18. Woje
    Woje Member
    48915, Lansing, MI
    Almost done
    Dave Johnson likes this.
  19. k-moe
    You can't. That's where the fuses are. When you took the gauges off you also disconnected most of the electrical circuits.
    Gauges are good. Gauges keep the bike legal. Gauges keep the po-po from handing you yellow papers.
  20. Woje
    Woje Member
    48915, Lansing, MI
    I understand there are fuses those fuses also can be by passed or 're routed with individual fuseable links without the entire bezel to all fit hidden in the headlight my gauges are busted from previous owner they don't work either way only reason leaving them on right now is to start the bike I'm replacing it with aftermarket eventually but in the mean time I would like to go without also the neutral light fuel light and oil light can be left on in this application as far as the fuzz each state has different requirement
  21. k-moe
    If you really want to you can wire in a fusebox that is small enough to mount in the headlight. Just trace the wires to see which fuse goes to which pair of wires.
    Woje likes this.
  22. XJ550H
    700N starter safety switch runs off of the stock tach
  23. Woje
    Woje Member
    48915, Lansing, MI
    Thank you I ended up just soldering fuses in with out the bezel so the entire wire harness with all lights and connectors stays in tact inside the headlight for now so when I'm able to find and can afford a stock replacement it's still bolt on ready
    Alan63 likes this.
  24. Woje
    Woje Member
    48915, Lansing, MI
  25. k-moe
    Those bags are going to get hot.
    Jetfixer likes this.
  26. hogfiddles
    And smell of exhaust too.....
  27. Woje
    Woje Member
    48915, Lansing, MI
  28. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That's quite the paint job on your helmet! I dig it.
