Adding extra lights..
Discussion in 'XJ Modifications' started by KAOS, Jul 14, 2008.
  1. KAOS
    KAOS Member
    Newport, Maine
    I bought an aftermarket round headlight n turnsignals. N yes I got a new flasher as well.. I'm going 2 be adding some LEDs on each side of my bike. Now I'm thinking I'll hardwire the power wire 2 the + battery terminal with an inline fuse n toggle switch..
    Now my questions r:
    Should I wire it that way?
    Should I wire it 2 the fuse panel? If so 2 which fuse?
    Should I "splice" it into my headlight power wire?
    OR Any other ideas?
    Thanx
    KAOS
  2. Altus
    Altus Active Member
    London, Ontario
    Your best bet would be to replace your fusebox with a modern blade-style box that has extra circuits. Then you can run power through a dedicated circuit & fuse, plus you get more reliable main fuses too.
  3. KAOS
    KAOS Member
    Newport, Maine
    I am updating my fuse panel. I'm gathering my parts list 4 chacal.. :) So when I get my fuse panel. I should wire it in 2 it with its own fuse!?! If so what amp fuse should I use then?
    Thanx
  4. Stamplicker
    Stamplicker Member
    London Ontario
    I wouldn't go any higher then 10A if it's just the led's, you could get away with 7.5A. Don't know how many in total,(Leds), you have planned.
  5. KAOS
    KAOS Member
    Newport, Maine
    Just 4 LEDs.. But maybe 6..
  6. Altus
    Altus Active Member
    London, Ontario
    Oh yeah - for that a 5 amp fuse would be fine
