Aftermarket gas cap
Discussion in 'XJ Modifications' started by kwes, Jan 3, 2015.
  1. kwes
    kwes Member
    tampa
    I have an 83 Midnight Maxim 750 current gas cap isn't sealing properly. Any ideas on where to find an aftermarket one? I know i can get an original one but I'm in the mood to splurge (lol) and find a cool custom one. any ideas I have seen some nice ones on here just not sure about the mechanics involved when replacing the stock. (if it needs to be vented, if a universal screw on one will suffice etc) thanks in advance.
  2. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    my aftermarket cap won't seal and I'm annoyed with trying to get one that works. Found the factory one on ebay for 20 that's the route I'm going
  3. kwes
    kwes Member
    tampa
    hmm i wonder if i can trouble shoot whats wrong with my orginal then.
    You can. It will need to be disassembled, cleaned, lubricated, and fitted with a new gasket. Be careful to not lose the small spring and check ball that lives inside the vent.
  5. hogfiddles
    They're easy to do.
    Dave
  6. chacal
    http://www.xj4ever.com/gas cap.pdf
    BTW, we do have the original style gold-plated gas caps available for the Midnight bikes.
    P.S. the $20 caps on eBay are not "originals", and you will encounter the same problems (among others) that Josh Phillips has........
    Josh phillips, Stumplifter and FtUp like this.
  7. kwes
    kwes Member
    tampa
    you guys are great! time to sign up for some more overtime to cover this growing parts list of mine. lol
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Going custom has its merits; however staying stock will give you less headaches.
    I strongly recommend that you acquire parts from XJ4Ever (Chacal) who posted just above yours.
    His reputation here is solid! :cool:
  9. Josh phillips
    Bettendorf, Ia
    How much is the factory cap from you? Midnight or not.
