Aftermarket light switch help
Discussion in 'XJ Technical Chat' started by ktp1598, Feb 20, 2012.
  1. ktp1598
    ktp1598 Member
    Mount Washington
    To replace my right handlebar controls (mine were physically broke) on my 1989 Yamaha radian I bought a new control made in china for the early eightys Virago. It looks the same except that it has a switch to turn the lights on or off. The start switch only has one pole so it won't turn the lights off as the stock switch did. I have all of the switches wired up except the light switch when I dropped it. It came apart and I'm not sure of it's reassembly. In the pic, the small white button you see between the slots has a spring under it that also acts on the switch plate. The problem is it looks like a ball bearing or something similar should be on top of the white button but I can't find it. I'm not sure it had one. The white plastic button gets stuck on the slots so I must be doing something wrong. Anybody have one of these aftermarket switches they can look at? My new switch looks like this ebay item: http://www.ebay.com/itm/Yamaha-Virago-X ... 3cb3dea5e4
