Aftermarket Tachometer not responding '82 XJ750
Discussion in 'XJ Modifications' started by Hakoo, May 21, 2015.
  1. Hakoo
    Hakoo New Member
    United States
  2. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    Im no pro with this but it seems like this is wanting an electrical driven tach, it came with magnet sensors for speed which is awesome but it doesnt compensate for the fact that our tach is mechanical as well IE: A spinning wire inside of a cable running to your tach.....now I could be wrong like I said im no pro and am often wrong so im prepared for the hazing if im not right lol but that appears to me the issue. The wires coming from the atari were purely for lights
    freserf likes this.
  3. k-moe
    All XJ750 models have electronic tachometers (as do 1982 and later 650s). The ATARI does a lot more than shine pretty lights. It shines warning lights. Those warning lights connect to systems that need to be bypassed for the bike to be rideable if the ATARI is removed (this has nothing to do with the aftermarket tach not working though).
    On to the problem at hand.
    On the 750: Black is the bulb ground, Brown is the Bulb feed, Grey is the signal from the #2/3 coil. If your tach does not work with the signal from the grey wire hooked to the gauge's blue/white wire, then either the gauge is defective, or the grey wire has a break somewhere between the gauge and the 2/3 coil.
    If the gauge does turn out ot be defective then I recommend you return it and buy from KOSO. You have a knockoff that is made in mainland China. The KOSO gauges are worth the extra money.
  4. Josh phillips
    Bettendorf, Ia
    ahh shit see there goes me not knowing anything about any XJ but my own lol sorry man
  5. k-moe
    Mistakes are how we learn :)
    Josh phillips likes this.
  6. bubba650
    bubba650 Member
    Miami
    IMG_0324.JPG photo_4.jpg hOW WOULD YOU WIRE THESE TOGETHER BEEN TRYING FOR THE PAST 3 WEEKS CANT FIGURE IT OUT. ITS FOR A 81 XJ650 MAXIM
  7. Hakoo
    Hakoo New Member
    United States
    I got my replacement gauge in case the one I received was toast, but with the new gauge I still get no response on the tachometer.
    I'm going to check tomorrow to see if there is a break in the wire anywhere, but the tachometer on my old Atari worked.. So who knows.
    Any other ideas, anyone?
  8. Hakoo
    Hakoo New Member
    United States
    Bump... would really like a working tachometer! Even if I have to buy a solo tach!
  9. Raven
    Raven Member
    Twin Cities, MN
    When I was wiring my aftermarket tach, I THINK it was Red (tach) to Tan (bike), Green (tach) to Grey (bike). Blue was for the backlight. The one I got was like this though (on the right, obviously):
    I'm not sure if maybe there's another wire on the gauge you got that needs a different connection? I hope that helps, if even a little!
    Hakoo likes this.
  10. Hakoo
    Hakoo New Member
    United States
    I'm going to take a good look at it tonight and make sure that everything is connected and there's nothing I've missed.
    Where did you purchase that Tachometer?
  11. Hakoo
    Hakoo New Member
    United States
    Bump, looking for a replacement tachometer at this time.
  12. k-moe
    Those gauges are available from several sources; MikesSX being one.
  13. XJ550H
    pilot box photo
    high beam
    blue wire to yellow wire in connector
    blueblack wire to black wire in connector
    winker/blinker
    yellow wire to d/g wire in connector
    yellowblack witr to c/h wire in connector
    oil
    red wire to r/w wire in connector
    red/ black wire to b/r wire in connector
    neutral
    green wire to Bn wire in connector
    green/black wire to sb wire in connector
    back light
    tach photo
    orange wire to blue wire in connector
    yev likes this.
  14. ABORDNER
    ABORDNER New Member
    United States
    Hello I am new to the forum so I really appreciate all the helpful stuff posted on here. K-moe you mention being able to bypass certain parts of the atari for the bike to be rideable. Do you know specifically how on a 1982 xj750 maxim? Anything would help.
  15. Toomanybikes
    Tsawwassen bc
    Is the tach grounded correctly ?
  16. k-moe
    Atari Delete
  17. ABORDNER
    ABORDNER New Member
    United States
    Thanks a ton! I was able to find it yesterday.
  18. Hakoo
    Hakoo New Member
    United States
    As far as I can tell, yes. There is only one ground wire on the entire gauge cluster, and it is grounded properly to one of the bikes existing ground leads.
  19. k-moe
    Which lead?
