air jets
Discussion in 'XJ Technical Chat' started by jeishen, Jan 18, 2012.
  1. jeishen
    jeishen Member
    North Port, FL
    I cant find the thread about the correct position of the main and pilot air jets and which manual has the correct positioning. Could someone Identify the correct position of the link to the thread. Thanks
  2. bigfitz52
    I can tell you the Haynes has them backwards... if that helps (at work, reference materials at home.)
  3. TIMEtoRIDE
    The larger jet feeds the Emulsion tube and "piston slider needle"
    The smaller jet feeds the "Pilot" system, and is towards the throttle butterfly.
  4. jeishen
    jeishen Member
    North Port, FL
    Thank you I have a feeling its not right
  5. chacal
    Nope, exactly backwards for the AIR jets........the smaller air jet is for the main fuel circuit and goes in the center hole. The LARGER air jet is for the pilot fuel circuit and goes into the forward hole.
    The rear hole is for a cover plate hold-down screw............many models of Hitach carbs do not use the air jet cover plate, so don't worry if it's missing.
  6. TIMEtoRIDE
    Chacal is right - I was thinking fuel jets
