Another xj650 bobber work in progress
Discussion in 'XJ Modifications' started by Big_P, Mar 3, 2012.
  1. Big_P
    Big_P Member
    EDIT:
    Pretty much done now. Last page has more pictures.
    First off i apologize for the large pictures i have no idea how to make them smaller..
    I picked up this 1980 xj 650 in January and have just been doing what i can when i have time. Between school, work, weather, and money i havent gotten much done but heres what ive got so far.
    First impressions
    Got her cleaned up a little and threw on some cheap mx handlebars i had laying around.
    Cardboard seat pan mock up i made
    Cleaned and temporarily repainted the wheels with anti rust paint
    Brought her back to my house to work on in my dads shop and keep out of the weather. Chopped the back of the frame off painted the rear fender and also got the seat i ordered. Just need to figure out how i want to mount them.
    Also while i had time with my dad we checked the valves (all were in good shape/spec)
    She runs like a champ with no starting problems or idle problems!
    Carbs, master cylinder and brake lines were rebuilt by PO.
    Still lots of work and customizing to be done though.
  2. boostenlebaron
    boostenlebaron Member
    Sturbridge MA.
    Nice, looks alot like my bike.
    How did you go about mounting the rear fender? Im still trying to figure it out.
  3. AngryGnome
    AngryGnome Member
    Moorpark, California (USA)
    i second that question. lookin goood!
  4. Big_P
    Big_P Member
    Thanks. Spring break is next week so ill be able to do a lot more. I cant really explain how im mounting the seat and fender but ill take some pictures and maybe that will help.
  5. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Dude keep up the good work. Are you planning on doing anything to the carbs? Hard tailing or keeping it sprung? BIG PICTURES RULE BTW!
  6. Big_P
    Big_P Member
    Thanks man! The carbs were rebuilt by the previous owner so im going to leave them alone for now unless i decide on a 4-1 exhaust. I think im just going to stay with a soft end but im going to get shorter ones (11" eye to eye) Id really love to do a hard tail but i think ill save that for my next project.
    What i plan to do over spring break
    -Mount the seat and rear fender
    -Cut the front fender down
    -Different throttle housing without the start button/run stop switch (dirt bike style)
    -Different gauges, probably the single speedo from mikesxs
    -New paint all around
    -LED turn signals
  7. boostenlebaron
    Sturbridge MA.
  8. HirsuitHeathen
    South Jersey
    Sweet, sounds like your building a brat style bike. I did the Mac 4-into-1 exhaust and jetted the carbs with a stage 3 Dynajet kit and ran pods (not sure what brand). I like the single speedo deal although mine isn't hooked up it came from a '75 RD. It just shows that my headlight is on high or low and blinkers which I took off.
  9. Davidkal
    Davidkal Member
    Great lookin project.
  10. Big_P
    Big_P Member
    Some updates:
    Got the rear fender mounted using these bolt rivets
    They have threads on the inside so i just drilled a hole and used a special tool to pop them in and bolted the fender on through the existing holes.
    Also got the front fender, rear and front wheel, and valve cover painted
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    I'd suggest capping/blocking the holes in the rear where you cut, otherwise you will get a serious rust problem.
    Just for the hell of it, put a rag on the end of a straightened out coat hanger and stick it in there now, you may be surprised/shocked at what comes out.
    If it's bad soak a rag in oil and swab the inside of the tube, it might help.
  12. Big_P
    Big_P Member
    Yeah im planning on capping them either with the shotgun shell idea or making some myself. Thanks for the hanger idea though ill give it a shot.
  13. dirticops
    dirticops Member
    Don't be scared chop that frame :)
  14. Orange-n-Black
    Memphis Area
    Looks nice and please do cap those rails.
  15. AngryGnome
    AngryGnome Member
    hey man thats looking mighty nice. thanks for clearing up that fender mounting question. i really appreciate it
  16. Big_P
    Big_P Member
    Almost ready to ride...
    To mount the seat i welded two tabs on the sides to bolt to the outside of the frame and one hook in the front to go where the old one slid into it fits really good. Ill post pics if that's not clear enough.
    Also one of my dads friend messes around with machining parts a lot and he made some silver shotgun shells for the end caps on the back of my frame and instead of the usual words on the ends he can put whatever i want it to say. Its going to be awesome!
    I just cut up the old seat cover for my seat pan and thats what im going to wrap it in but for now its just sitting on there to see what it will be like.
  17. Big_P
    Big_P Member
    Things i still want to do..
    -License plate mount/brake light
    -Small turn signals
    -Shorter rear shocks
    -Different handlebars
    -Different throttle assembly/grips (have one on the way in the mail but not sure if it will fit yet)
    -New tires
    Also on the rear brake adjuster bar thing that goes from the back of the brake pedal to the drum brake i need to find a new wingnut to replace the old one (it was striped) but i have no idea what size it is...... if anyone can help me out that would be great.
  18. strat
    strat Member
    Williamsport, PA
    where did you track down those rivots?
    I could really use something like that to get my rear fender mounted on my bike.
  19. SuperSeca44
    SuperSeca44 New Member
    Seattle, WA
    did you replace the gasket on your valve cover when you painted it? mine leaks all over my exhaust!!!:(
  20. boostenlebaron
    Sturbridge MA.
    Harbor freight sells the rivet kit for 15 bucks. Or you can buy your own rivits and make the tool using a few scrap piece of metal and a bolt.
    Look up rivet nuts or threaded rivets to find them.
  21. Big_P
    Big_P Member
    What he said about the rivet nuts ^^ its really simple. I haven't replaced my valve cover gasket but i need to it looked a little worn i just didnt have the time and there haven't been any leaks but its going to get done sooner or later.
  22. SuperSeca44
    Seattle, WA
    I got ya... can you take them off without removing the engine from the frame?
  23. mtnbikecrazy55
    what shocks are on there now? stock ones?
  24. Big_P
    Big_P Member
  25. deadohiosky
    deadohiosky Member
    Columbus, OH
    Lookin' good! And I thought my seat was thin lol!
  26. Big_P
    Big_P Member
    Haha no need for cushion she's still a soft tail ;)
  27. Big_P
    Big_P Member
  28. kudoskun
    kudoskun Member
    Minneapolis MN
    How does it sound with the muffler-less exhaust? It looks like you just run right out of the headers under the body there.
  29. Big_P
    Big_P Member
    Yeah they are cut off right under the footpegs from the previous owner. Its loud... really loud haha and doesnt have enough back pressure so it pops every now and then.
    But im just waiting to get a 4-1 system soon.
  30. warchol2
    warchol2 Member
    st.clair MI
    looking very good, how did you paint your gauges? and what are you using for side covers?
  31. Buffalony
    Buffalony Member
    Corning NY
    Looks great so far. Where did you order the seat? Did you send them the cardboard template to make a seat from?
    btw. I might take those crash bars off your hands for my gf's pretty nonbobber if your not gonna use em. :D
  32. Big_P
    Big_P Member
    Well its been a while since i posted in this forum but i thought i would show the updates ive made to the bike.
    Chopped the frame and lowered the rails where the seat sits
    Some z-bars and I Have led blinkers on my forks just above the belt but i still need to get some for the rear.
    This is where i relocated my start button for now until i get some new sides..
    by the way, anyone here have a pair of side covers they want to sell? ha
  33. Ted
    Ted Member
    Sioux Falls, SD
    Looks good man! I've been thinking about switching to those Z bars too and I dig your seat.
  34. Big_P
    Big_P Member
    Its been a while since i have updated this, but it almost spring and im getting stir crazy and can't wait to start tweaking the bike some more.
    As of now this is how it has been sitting for the winter.
    -I finally put some forward controls on - feels so much better
    -Put some blinkers in the rear where the shotgun shells used to be
    -Relocated the ignition to right below the side cover
    -Rebuilt the carbs and have all the valves in spec (runs mean now!)
    -I also got a mod that holds my cell phone on the handlebars and doubles as my new speedometer - works great!
    Here are the pics i have right now
  35. Ted
    Ted Member
    Sioux Falls, SD
    Still looking good, Big_P! Looks like we got the same tires & controls now! I'm still digging those Z-bars... wanna trade for some TC Bros. Lane Splitters? 8)
    What did you use for the in-frame turn signals? Those are pretty slick.. I've thought about trying something similar since I'm running no signals now. I just stuck a couple of little chrome plugs in my frame holes but I've been kicking around the idea of mounting some little LEDs in the plugs.
  36. Big_P
    Big_P Member
    Thanks man! Im diggin the z bars right.. so ill pass on your offer ha. I got them online at scooterworks for pretty cheep though 20-40 bucks.
    I really want to get some smaller controls and master cylinder.
    And the turn signals were just bought at autozone.. they aren't LED's but they get the job done. Just fit them right in with some silicone, drilled some holes farther down, and fished the wires through.
  37. XjSeca TJ
    XjSeca TJ New Member
    UK
    Hi, I know this is an old thread but can you tell me whether you have just reused your existing Maxim rear fender or whether it is off another bike.
    I have a XJ650 Seca 1981 which has a different rear end.. Cheers Buddy
  38. jayrodoh
    jayrodoh YimYam
    Cleveland
    Dudes been gone over 1.5 years so I doubt you'll get a response. That said, looks like the original fender rotated forward. There are others on here that have done that as well.
  39. XjSeca TJ
    UK
    Cheers for the response.. it does look good the way he's done it.
