any one use LED turn signals??? How do you make them blink
Discussion in 'XJ Modifications' started by bossnoss77, Aug 7, 2009.
  1. bossnoss77
    bossnoss77 Member
    orem utah
    I am currently in the process of installin turn signals, 14 led ones.
    im sure they dont draw enough voltage for the flasher to pick up on the resistance. Any advice would be helpful. Do I need a resistor or a diffferant flasher? Thank you in advance!!
  2. razz1969
    razz1969 Active Member
    Cleveland, Tx
    buy a load equalizer from j&p cycles
  3. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Yup...whut he sed.. ;)
  4. tomandjerry00
    tomandjerry00 Member
    Washington DC/Philadelphia
    You can also buy a $3 electronic flasher (as opposed to the thermal ones on our bikes) from your local PepBoys or the like. Search the forum here for LED flasher and you can find a few threads giving you a step by step guide with part numbers to installing LED flashers. Good luck!
