Any tricks to removing gas level sensor from an 85 X tank
Discussion in 'XJ Technical Chat' started by dayooper951, Jun 6, 2007.
  1. dayooper951
    dayooper951 Member
    SE Michigan
    I picked up a new to me 85 700 Maxim X. I'm sending the carbs off for a vacation at the spa for some rejuvenation in the mean time I'd like to treat the fuel tank to Por 15 system, or may call some radiator shops to see if they have a reasonable method for sealing.
    The trouble is I removed the petcock and tank from the bike, but after removing the screws to what I believe to be a fuel sensor in front of the petcock, it won't come off.
    Is it suppose to? Any tricks, need to know info, etc?
    TIA
    Steve
  2. capy
    capy Member
    Florida
    Re: Any tricks to removing gas level sensor from an 85 X tan
    There is no trick it is just stuck. Once you get it to break loose, it just comes right off. Tap it lightly with a rubber mallet or something soft after dousing with P.B. Blaster or significant penatrant.
  3. nammy
    nammy Member
    Upstate New York
    My sencor was hard comming off too, but it did with a little force.
  4. dayooper951
    dayooper951 Member
    SE Michigan
    Thanks for the info, I had to use the PB to help in removing the two screws for it. Didn't want to use my caveman instinct and damage something trying to remove it.
  5. capy
    capy Member
    Florida
    While you have it out, don't forget to double check the solder joint on the single wire to the back of the sensor. I have had to resolder mine twice already. I am not sure if it is a vibration problem or not but it pops the wire right at the begining of the solder.
  6. dayooper951
    dayooper951 Member
    SE Michigan
    Capy, I'll take a look at it. Thanks for the info.
