Any way to convert XJ600 3km 1989 to 17 inch rear rim?
Discussion in 'XJ Modifications' started by gpspl, Nov 29, 2023.
  1. gpspl
    gpspl New Member
    Hamburg
    Hi.
    I'm looking for a way to "easy" 17 inch conversion for rear rim. I need to put winter tire to my xj600 and all options seems to support only 17 inch. Now I'm using k60 winter silica but they are not good enough for my climate.
  2. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I did a 17" x 3.5" conversion and it was not easy. It involves two wheels, I used early R1 front wheel for the spokes and rim and rear disc brake hub from an XJ900 i think..machine work, (lathe) and TIG welding'
    There are pictures on this site, but it's not an easy project. The finished product is much to my liking and I would do it again, no regrets.
    Cheers, 50gary
    chris123 and Franz like this.
  3. Simmy
    the XJ600 is chain drive so a much easier task.
    However, the OEM 600 rim is very skinny and most 17" will be wider, offsetting the chain alignment, and the disk brake as well, even if it fits in the swingarm.
    I didn't know winter rubber compounds for motorcycles existed?
    In Canada it would be a knobbie with sheet metal screws LOL.
    chris123 likes this.
  4. gpspl
    gpspl New Member
    Hamburg
    I will try gs500 wheel and we will see. It's 3.5 inch. Swingarm is not much wider than on xj600. If it will somehow fit I will just have to find a way to machine offset front sprocket
  5. gpspl
    gpspl New Member
    Hamburg
    It's even narrower than stock xj600 swingarm. Entire swingarm is 3mm wider on mount point to frame so maybe entire swingarm swap. We will see
  6. LAB3
    LAB3 Member
    Traveling the U.S. with no fixed address
    Having lived the majority of my adult life in northern Michigan I'd tend to agree with you on not knowing about winter tires and putting screws into the knobs. It seems that over in Europe they see things a bit different when it comes to riding in the winter!
    Right now I'm in central Florida and it's pretty rare to see anyone else on the road when the temp goes below about 70° except those of us from out of state. Guess it's a matter of perspective.
  7. gpspl
    gpspl New Member
    Hamburg
    It's more about my village where they don't remove snow from roads and it packs and turns into ice cape. Riding on asphalt is fine even on my fzs600 with road 6s but xj just has too narrow wheel to not get slipped on ice from time to time
  8. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i converted the rear of my xj600 to a 16" wheel and tyre from a yx600 radian, wheel fits same sprocket carrier and only requires the r/h side calliper mount to be milled down to fit, cant remember by how much , but its easilly measurable , but you have to convert to rear drum brake from Radian
  9. 50gary
    Saginaw, Mi. USA
    What a dummy, I didn't realize the bike was chain drive, excuse me\.
    Cheers, 50gary
