anyone ever try building a custom airbox.
Discussion in 'XJ Modifications' started by anton80, Aug 16, 2011.
  1. anton80
    anton80 Member
    concord ca
    i was just wondering if anyone has ever custom built an airbox for a 85 xj 700. im really thinking of making one. im over the damn pods i just wana go back to stock on my bike but would like to custom make one. is there a size limit that it has to be???
  2. Ledicott96
    Ledicott96 Member
    North west England
    I was thinking about making/modifying one to fit a custom wiring loom. As most of the wiring is where the air box is supposed to be.
    Al
  3. Libertas
    Libertas New Member
    SL,UT
    Anton80, I just picked up something along those lines. I will get you pics of how you could moc it up in the next few days. I have been in the same boat as you.
  4. anton80
    anton80 Member
    concord ca
    thanks libertas id really appreciate it buddy. Im just fed up with taking my carbs on and off allready and i havent eaven started trying to re jet my carbs
    so with that being said its time to custom make one. But im wondering can i just make a box and drop a air filter in there
  5. kevineleven
    kevineleven Member
    Columbus, Ohio
    Ride over here and I'll make it run right with your pods.
  6. anton80
    anton80 Member
    concord ca
    thanks for the offer kevin i wish i could believe me Ohio is a little far away
  7. bigfitz52
    All the way from 2K to redline?
  8. SBSTebbe
    SBSTebbe Member
    Michigan
    Hell I live in Michigan and if I run into too much issue I'll take you up. haha.
  9. kevineleven
    kevineleven Member
    Columbus, Ohio
    Actually from 1050 on up
  10. schooter
    Schooter likes this
  11. dwcopple
    dwcopple Active Member
    bay city, michigan
    mine, filter is a HEPA filter from a vacuum. Works very well and was simple to hack up and modify. Tons more room now too!
  12. bigfitz52
    Fitz is messing with all of you and busting Kev's chops; he doesn't run a tach so he has no idea where redline is (nor does he care, his bike runs the way he likes.)
    I'm an airbox and stock exhaust guy, since I like to be able to cruise at 90 when necessary and still get 53mpg in the bargain.
    So you guys have fun with the pods. Schooter apparently doesn't believe in them, his latest creation is running NO air filtration whatsoever. Details, details, who needs a front brake, anyway? No DEER in Elkton, right?
    I think DW has the right idea; kind of the "best of two worlds" approach, and no boulders in his intake tract.
    Cheers, guys-- I need a beer, I just came off a 60 mile commute. (On my XJ.)
  13. kevineleven
    kevineleven Member
    Columbus, Ohio
    You're exactly right i do not run a tach or speedo (presently) on my maxim, but I know it'll go to max speed without missing a beat. I had it 116 with my Acewell on it a while back, but it's retired to the parts shelf. I for sure can cruise *around* 90 right there with you, Fitz. I'd make a video for you, but I'd still be doubted Re: my pod start/rev/idle video. So Ill just continue to bust chops and talk SHT and ride my perfectly tuned bike with pods. Cheers.
    Paul Reese likes this.
  14. RobDrech
    RobDrech Member
    Middletown, CT
    I don't get it. It this for an XS?
  15. kewlman
    kewlman New Member
    hopewell jct, NY
    i just put pods on my xj750 runs pretty good.. no problems so far.. i was going to run with half the airbox with a custom flange for a single cylinder shaped filter under the seat.. but just ripped it all off instead..
  16. dwcopple
    bay city, michigan
    XS400J Maxim mini XJ if you will
  17. schooter
    That picture was before my henry abe NOS breadbox
  18. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Thanks for sharing that DW... that's brilliant
  19. anton80
    anton80 Member
    concord ca
    i want to avoid all this re-jet none sense i am going to weld some 3by12 thin sheet metal and try to make a box from that i bought a stock air filter that im going to put in the box i just cant come up with a nice design for the box a plain old square box will look hoaky any thought on what can be done i have a 85 xj 700 air box that doesn't fit under my seat that i might cut up and try something with i just love the look of the pods but do not have the patience for re-jeting.... and taking the carbs on and off i've done it enough...
    funny thing is i just checked my plugs after my run around the block 1-3-4 are running rich but the #2 carbs which has a berried air mixture needle is fine real light brown but barely... and i am also thinking that my float levels are not set rite when i throttle the bike it chocks even in neutral like its not getting enough gas or is it to much gas????
    minor update....any help greatly appreciated
  20. dwcopple
    bay city, michigan
    look in the houseware's section for something made of rigid plastic that you could cut or drill for intake boots and house a filter too. PVC is another option. Be creative. That HEPA foam I used is awesome and cheap from a vacuum repair shop.
  21. 16ozbud
    16ozbud Member
    louisiana
    One and a quarter inch flex couplings from the plumbing section of the home improvement super(or not so-super)store fit nicely on the carbs. They are made of rubber and come with stainless hose clamps. Might be a good starting point.
