anyone know what would cause this??
Discussion in 'XJ Technical Chat' started by jdoggsc, Oct 10, 2009.
  1. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    so i turned my bike off and was clipping my helmet to it when i saw this on the rear gearbox. I didn't fill it through this cap--I filled it through the correct bolt about half-way up the height of the gearbox.
    any ideas what would cause this?
  2. backblast
    backblast New Member
    Louisiana
    Jdogg, I believe that is a 1-way breather valve for the case. Looks like you overfilled. I think there is a seal in that piece. looks like you blew it. Might have to buy another one. I may be off tho so may want to wait for more answers before jumping.
  3. BikerEd
    BikerEd New Member
    Fredericton NB
    This is your rear end not a gear box,you have overfilled it and as it warms up the oil expands and leaks out the vent. :)
  4. MiCarl
    Yep, just a vent. Under the cap is a little hole. That's all. Too full or getting too hot (although you should smell too hot).
  5. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    how can you overfill it?? You can't fill the oil higher than the filler hole on the side--it'll leak out. Is any other kind of oil/fluid/lubricant that could have leaked into that chamber through the drive shaft? I'm wondering if i have potentially much worse problems here.
  6. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    what would cause too hot? I don't have a sense of smell--i couldn't smell it if it was too hot.
  7. skippy344
    skippy344 Member
    Aggieland, TX
    I'm sorry, but I have to ask the dumb question...
    What weight gear oil did you put in the dif?
    I hope is was 80W90.
    If not, then you've got serious froth going on!
  8. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    yup. SAE 80W-90
  9. skippy344
    skippy344 Member
    Aggieland, TX
    OY! What the heck is going on in that dif??
    Man, I don't know????
    Drain the dif, see how much oil is in there.
    See if there is anything that shouldn't be.
  10. bigfitz52
    I agree. I'd REPLACE the oil in the differential and then see what happens. If the oil that was in there was old or had moisture in it it would foam/froth and seep out the vent even if not overfilled.
    If what comes out is really nasty I'd ride it a couple hundred miles and change it again.
  11. Gamuru
    Gamuru Guest
    Granite Falls, WA
    It's possible the vent was plugged to start with. After the pressure built up in the differential, it may have popped the obstruction spraying oil out the vent tube as the pressure equalized.
  12. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    hmm.. i guess that's possible. if it is frothy, and filled much higher than usual, is there anyway any other type of moisture/lube could have gotten in there?
