Anyone Recognize This Tailpipe?
Discussion in 'XJ Technical Chat' started by Jimmytime, Oct 11, 2006.
  1. Jimmytime
    Jimmytime Member
    Toronto, Ontario
    I'll try to keep this short (something I'm not very good at!)
    This bike, a 1982 XJ650 Seca, was given to me by a friend (given because of it's wonderful cosmetic condition!). I knew enough about the bike to know that it had an after-market pipe. I knew enough about bikes in general to ask my friend if when he switched pipes, had he re-jetted the carbs. He response was basically "Did I re-what the who?". So I am assuming that it still has the original jets in it. If it does I assume it would be running lean, and I think there is more evidence of that. It really gives me a hard time starting; I always have to give it a lot of choke, and it takes a fair amount of riding under load before the engine is warmed up enough to maintain an idle without choke (or stalling). At high speeds the power seems to "fade" at a certain point and it just won't go any faster. I replaced the clutch thinking it might have been the problem, but it wasn't. Also, the manifold was very rusty so I sanded it down and painted it with high temperature paint which burned through in about ten minutes of running. My brother (who knows more about these things than I do) says a lean engine will run hot which may explain the manifold.
    So!
    All this leads me to believe that I need to put larger jets in my carbs. Under some advice I've already recieved I was just going to go up 2 sizes, but I thought I would post pictures of the pipe here in case someone recognizes it and says "Oh! That's a so-and-so pipe! Put in this size jets." I've never changed jets in a bike before, so I'm not even sure if it's ever that easy!
    Also, if I do end up going up 2 sizes, will I have to change the needle? And what about the other, secondary jets like the "Idle Jet"? Do I just leave them as is?
    Thanks in advance! I'll include a photo of where the pipe's label was, the sticker long since gone!
    Jimmytime
  2. thefox
    thefox Member
    Central NY (@ college in W. PA)
    Looks like a MAC exhaust to me.
  3. RickCoMatic
    That flange holding the header pipe into the exhaust outlet looks to be like that of: "Jardine"
    I had these pipes on a '79 XS650 Special. I bumped-up the Main Jet one size and it ran great.
  4. Jimmytime
    Jimmytime Member
    Toronto, Ontario
    Thanks for the responses! I'll investigate these 2 brands further.
