ARGHHH!!!??**
Discussion in 'XJ Technical Chat' started by guzzijohn, Nov 30, 2008.
  1. guzzijohn
    guzzijohn New Member
    8O Got head&cylinder off b4 lunch. The 2 front rt side inner studs are rusted,the one w the aligning dowel is eaten enough to be weak. The bores had a little rust but not bad enough for rebore. It looks like I may seek donor engine but $ tight-like 4 everyone. May try a swap of the xs360 for a crasher or some such w good mill. I'll get her stripped completely and boxed up. It looks like the Buffalo will get assembled sooner. :wink: Guzzi John
  2. Zookie400
    Zookie400 Active Member
    Connecticut
    i thought i saw an engine posted for an XS on this site........... i could be wrong.
  3. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    What kind of Carbs do you have on the Buffalo John ?
  4. guzzijohn
    Hi,My Buffalo is stock but for J&R pipes and Newtronic ignition. Had it running summer b4 last but suffered coolant leakage into tranny so stripped again. They are a neat machine(I'm an old 2stroke nut-many Bridgestones and my RD400 racer)it cruised like a turbine at 75 but was thirsty at that speed. :wink: GuzziJohn
  5. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Was just curious as I remember some of the waterbuffalo's had CV carbs(why I dont know!).
  6. guzzijohn
    yup they're cv's-no boggum carbs,early models had plain slides. CV's aren't hiper but they do a good job all around.GJ :roll:
