Attaching Petcock to Gas Tank
Discussion in 'XJ Technical Chat' started by CafeBlack, Apr 4, 2016.
  1. CafeBlack
    CafeBlack Member
    Hi again,
    Just finished refurbishing a petcock for an XJ900F and about to attach it to the newly painted gas tank.
    Apart from the O ring (or Oval ring as it sits in the groove), is this sufficient for a tight non leaking fit to the tank?
    Would the addition of a gasket sealant or something like Yamabond or similar spread around the area of the O ring be a recommended added security against petrol leaking through?
    Many thanks!
    No sealant, just the o-ring.
  3. quebecois59
    you also need the asbestos-like washers to seal around the two petcock bolts, obviously.
  4. CafeBlack
    CafeBlack Member
    Thanks for that.
    Yes I have the original washers and screws. A slight clean up and they'll be used to mount the petcock back on the tank tomorrow.
