Back view camera etc.
Discussion in 'XJ Technical Chat' started by Gymer, Jun 13, 2013.
  1. Gymer
    Gymer New Member
    Houston
    I wanted to post some modification of my 83 XJ750K. I added a camera on the tail "sissy bar." On the faring above the gauge cluster you can see the view screen and a mount for my smartphone. I sometimes use the GPS function of the phone. The view screen is visible in daylight albeit a little dim, but at night, I have to actually dim it is so bright.
    The LED light is both running and stop light for more visibility.
    Interestingly I have been having start problems, which seemed to boil down to a bad ground. I'm still "test" driving how long until and if I get a no start problem that I thought was the TCI/CDI.
  2. pjk_xj700
    pjk_xj700 Member
    Northeast Lower, MI
    Ha, that's pretty cool. I'm tinkering with mounting my droid on my bars as well, but have run into a few issues I need to resolve.
  3. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    Hey Gymer, Welcome to xjbikes!
    Where'd you get that tail light? I am looking into add'l light/visibility options. I like that one.
  4. biggs500
    biggs500 Active Member
    Sherwood WI
    Interesting shocks Gymer. Two different springs. Are they Mulhollands? I have those on my Seca.
    Also have you ever thought of removing that large, ugly licence plate holder that was designed for a larger plate? Like the size they were in the '80s?
    See, looks much nicer. :D Mounted mine right to the underseat storage box.
  5. Gymer
    Gymer New Member
    Houston
    ColoradoDan, I used and LED from O'Reillys and just was able to fit it just so.
    biggs500, Now that you mention it, your right. I never paid attention to that it was oversized. I may paint the space around the license black, or like you make the whole thing smaller. As for the springs, that's what was on the bike when I got it from my brother. He had it modified to a four in one exhaust FYI.
  6. RickCoMatic
    I run a trio of Red LED's on the rear of my seat.
    They are powered by a "Back-off" Module from SignalDynamics.
    When I brake they flash several times before coming-on full.
    As often as the switch is opened and closed the Module resets and begins the sequence all-over again.
