Bad flasher relay
Discussion in 'XJ Technical Chat' started by carbonxe, May 1, 2011.
  1. carbonxe
    carbonxe Member
    My flasher relay went bad and was popping my signal fuse. I replaced the relay with a generic 3 pin flasher relay from an automotive store, and now my flashers don't work at all. Do these bikes need a specific relay, or could something else have gone wrong with the circuit?
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    If memory serves, you have to swap 2 of the three wires to use a generic relay.
  3. carbonxe
    carbonxe Member
    Thanks, that could easily explain it. I guess I'll just leave it alone while I convert the signals to LED.
  4. Robert
    There is a thread in the FAQ suggestions (I think its there anyway, I could be wrong about location) that has the pinout and suggested wire swapping listed. You might want to take a peek before too long.
