Balancing them carbs
Discussion in 'XJ Technical Chat' started by andrew15, Apr 4, 2015.
  1. andrew15
    andrew15 Member
    Montreal, Canada
    Today i'll hopefully be balancing my carbs... we had nice weather yesterday but today it's going to be sitting at around 2 degrees celsius, 35.6 degrees fahrenheit for y'all ;)
    1) Will the weather be a problem once I warm the bike up?
    2)Let's see if I got the steps right here... I'll be using the 2 bottle sync tool.
    a) Warm the bike up
    b) Balance carbs 1&2 -> 3&4 -> 2&3
    c) check em again and adjust as necessary
    I've already bench synced them and set the fuel levels
    I'm wondering where the idle adjustment rod comes in to play?
    Should I be trying to keep the idle at 1050+-50 while I'm doing this?
  2. MiCarl
    Yes, you want to keep the idle at the target speed. It'll move around as you adjust the sync and you use the adjuster to bring the RPMs back where they belong.
    Add a battery charger while you do this. You have a reasonable chance of discharging the battery with all the idling it'll be doing. Plus, you might be restarting the bike as you move the bottles around.
    Your sequence of tackling it looks right to me.
  3. k-moe
    The outside air temperature will not matter. Each cylinder will pull the vacuum that it will pull regardless.
  4. andrew15
    andrew15 Member
    Montreal, Canada
    That's what I like to hear guys!
    It'll be a wee bit cold but I want it done today haha
  5. XJ550H
    you have a regular heat wave going on there. its snowing where I am 30 f going down to 21F
