Battery charger vs Battery maintainer
Discussion in 'XJ Technical Chat' started by raskal, Dec 23, 2019.
  1. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    I have a "electronic" battery charger that I have used on my boat battery with good success. I'll typically put it on the charger every 2 weeks for a couple of hours. I have no problem maintaining a schedule (I use a calendar app for reminders)
    Should I use the same charger on my XJ's battery or should I invest in a maintainer (eg: Battery Tender Jr) ?
    lastly, if you suggest a maintainer, what do you think of this one https://www.amazon.com/MOTOPOWER-MP00205A-Automatic-Battery-Maintainer/dp/B06XWDZ2KQ
    That one is $20 in Canada vs $54 for the Battery Tender Jr. right now
    thanks and Merry Christmas, I hope Santa brings you a new parts bike
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    My bikes stay on a maintainer at all times--Battery Tender, Jr. I didn't pay anywhere near $54 for them. However, I don't see any reason that one would not work. Plug it in and leave it on.
  3. XJ550H
    any cheap trickle charger will do the job
    if your current charger trickle charges you will be fine
  4. XJ550H
  5. raskal
  6. raskal
    trickle chargers, I've read, aren't great cause they don't shut off and end up over-charging batteries
    I think I'll just buy a maintainer and not have to worry about being on time to avoid over charging
    thanks guys!
  7. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have a $10 harborfreight battery maintainer that I keep plugged in over the winter and any time I'm not riding for a few days. Works great.
    For actual charging of a new or low battery, I have an old 1 or 4 amp charger.
  8. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    It depends on the cell type. If it's a flooded battery you should charge it with an auto-shutoff charger and keep it topped off all of the time using a float charger like the cheap clip-on ones (not a Battery Tender). It's a very low current(<500mA at 13V) power source that keeps the chemicals separated. An AGM is more finicky about charging rate and how you maintain them. A decent lead acid battery maintainer will adjust the charging amperage on any lead battery based on the voltage and keep the battery at peak charge with less than 1amp of charging. The Battery Tender small pack is made to do that which is why they are so popular.
