Battery life
Discussion in 'Hangout Lounge' started by tabaka45, Nov 1, 2018.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I hav been getting about 2 - 2 1/2 years from my replacement batteries. I got almost 6 years out of the original battery in my Honda 750. Doesn’t seem to matter what battery I use. (I have just bought a Big Crank battery which is highly rated—higher than a Yuasa.). Batteries stay on a Battery Tender Jr when parked. Just wondering what other folks are getting.
  2. Jetfixer
    Your charging system might be putting out more voltage than is required in essence you can "cook" the battery . I had an 82 Honda CB750 custom with only 4500 miles , but the charging system was inop . Had to replace the rotor and all was good , you might check output , your voltage regulator etc.
  3. XJ550H
    I just replaced my battery got almost 3 years out of it got the battery at walmart.
    battery is probally the most neglected item on the bike I check fluid level every 3 weeks
    also check the voltage output from alt when I do this.
  4. tabaka45
    Brunswick, Georgia
    I have been buying AGM batteries and keeping them on a battery tender, jr. But I did buy a conventional battery from Interstate and it lasted about 7 months before it completely dried out and exploded. I guess the trickle charger I was using was not as “intelligent” as the Battery Tender is.
  5. Toomanybikes
    Tsawwassen bc
    I have 6 battery tenders and get between 4-5 years out of my batteries.
    And every second wreck I buy there is a nearly new battery in it. Haven’t purchased a new one in nearly 7 years.
  6. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I buy "Walmart" type lead acid batteries and was getting about 2-3 years out of them...this summer I rebuilt my starter and pretty sure it is drawing less amps, so hopefully batteries will now last 3-5 years like they did when it was new.
    I check the fluid level periodically and use a battery tender regularly. I pay about $40 typically depending on where I buy them.
  7. Jetfixer
    I switched to the AGM battery , so far with good results.
  8. k-moe
    Trickle chargers are just that; a steady voltage at 1.5 - 2 amps. They won't shut the charging voltage off when the battery reaches capacity.
    Colin 85 700 likes this.
  9. Jetfixer
    That is why I only leave my 1 amp charger on for an hour or 2 once a week
  10. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    So far, knock on wood, both battery tenders have not had an I'll effect on the regular flooded cell in the 81 or the agm in the 82. These are 750mA models.
  11. k-moe
    For perspective:
    My wife and I have a Miata that we rarely drive. It's on a tender about 300 days of the year, and the battery is going on 12 years old now. Still starts every time.
    Even maintaince free batteries require maintainance if a vehicle is not used daily.
  12. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    I bought my bike 2 years ago, never charge it, it sits outside covered for the winter at -40 and in the spring it just starts.
    I assume it will be the same this year.
    No idea what battery is in it, never had to pull it out.
    I've never trickle charged a battery for winter (or summer for my sled) mine always last 4-5 years. unless something draws on it a good charged battery won't freeze or loose power.
    However, NEVER! Take out a battery and put it on concrete or a steel shelf or bench top, it will kill the battery! Don't ask me why, I'm not a chemist, but it does.
    If you worried, disconnect the negative for the off season, if it's dead by summer it's no good anyways, it's shorted internally or has a bad cell.
  13. Polock
    here we go with the old wife's tales. i'm pretty sure it's on a metal shelf in your car. the concrete part is to save the concrete from the old batteries that leaked acid and etched the concrete
  14. hogfiddles
    And that was from back when battery casings were rubber, not the plastic we have now
  15. tabaka45
    Brunswick, Georgia
    I have a boat battery that sots on concrete all the time except for the few hours I use it every month. It stays on a battery tender an is at least 3 years old.
  16. Colin 85 700
    Thunder Bay, ON
    Well, not that i dont believe you guys, but i did a little reasearch and yes the concrete thing is an old wives tale passed down from old school batteries that had carbon in the casing allowing power to leech out.
    Also they would commonly leak acid, eating steel and etching concrete....
    Ive been learned :)
  17. hogfiddles
    Old wives tale.......
    My wife has an old tail...
    My old wife has a tail...
    Uh-oh......I'd better quit while I'm still ahead before I get in trouble
  18. k-moe
    That bit of wisdom comes from the pre-plastic era when battery cases were made of wood (and the early plastics that Dave referred to), and is not applicable to modern batteries.
  19. Richard Elbon
    Richard Elbon Active Member
    LaCenter Washington
    Are Optimas being made for motorcycles yet? I have one in every car and two motor homes. Best ever. My first red top was $60 in 1991. Put in my Dodge diesel it went 17 years,wouldn’t crank anymore went into my 55 Buick for another 5 years,wouldn’t crank that anymore and it went to my riding lawnmower with a home built bracket till fall of 17. Tried charging the heck out of it with my agm charger but can only get 4 volts. 27 years of use. It’s retired.
  20. tabaka45
    Brunswick, Georgia
  21. Richard Elbon
    LaCenter Washington
    Luckily the GS 1100E that I bought had a massive amount of spare parts including a new battery in the box with the acid pack.
  22. hogfiddles
    You're nuts!!!
    Why would you retire it with 4 volts still remaining? Put a shoulder strap on it and wire it to an LED bulb and you'll have a flashlight that'll be brighter and last longer than anything ar0und. Geez, man--
    Chitwood, jayrodoh and Simmy like this.
  23. Dave in Ireland
    Ireland
    I wonder where this myth started, because I've heard it for decades.
  24. k-moe
    Dave in Ireland likes this.
  25. Colin 85 700
    Thunder Bay, ON
