Battery not taking charge after 300km
Discussion in 'XJ Technical Chat' started by broberg, Jul 19, 2013.
  1. broberg
    broberg Member
    Sweden, Östergötland
    I took quite a long ride yesterday, ran like crap, fouling nr4 plug etc (only nr4)
    But anyhow, my current issue is that according to my dials (that have a volt-meter built in) My battery is down to 10V, and this get's noticed when slowing down and it goes down to idle and the dials die due to lack of power.
    BUT accordingly to the dials while at aprox 2k i get 14V output (going from 13.5-14.6 depending on rpm), and then on idle it registers 10.2 on the battery..
    Have I missed to connect something or is it just that the battery is so low that it can't take the charge from the bike? I will hook the battery up to a charger and get it up to 12v before I ride it home and see if it drops or stays at 12v after the ride.
  2. bikeboy929
    bikeboy929 Member
    mahtomedi, mn
    did you build the volt meter yourself? or was it stored outside over winter? it might not be getting a good reading.
    first thing i would do is check with a multimeter you already know is good and see what the voltage is at idle, and at 2k. if that reads 10.2 at idle also, then you have a problem.
    if you find you do have a problem, then you need to " trouble shoot" the electric system, there are great flow charts for this that i can link for you so you can find the problem( bad ground, connection, RR, or stator), but if your bike really is at 10.2 at idle, i would think that your battery would give out really quick from over pulling, and wouldn't hold a charge at all, so i assume its a bad reading
  3. bikeboy929
    bikeboy929 Member
    mahtomedi, mn
    one more thing i guess, did you wire anything extra on your self? heated grips, or cell phone charger or such?
  4. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    are you getting constant spark to #4? Any other wiring mods?
    +1 on double checking the idle voltage with a multimeter
  5. jmilliken
    Dillsburg, PA
    also - what type of battery do you have, lead acid, AGM, LiON?
  6. adrian1
    adrian1 Active Member
    How old is that battery. If suspect get a Motobatt. What voltage are you getting when bike is running at 3000K?
  7. bigfitz52
    My original voltmeter does leave a tad to be desired, accuracy wise. That being said, at speed I usually see the needle parked just above the 14V mark, right next to where the red starts.
    Put a real voltmeter on the terminals and see what you're getting at >2200rpm. If you see 14.5 ~ 14.7VDC then the problem isn't the alternator.
  8. broberg
    broberg Member
    Gave the battery a charge and hooked it up again, no change on the dial, but the multimeter on the battery shows 2 volt extra .. so 10.2 on the dial is actually 12.2 on the voltmeter.
    And when showing 13.5> it's about 0.5 lower on the battery side
    But thats the thing, I get such a drop in the voltage when going from gear to idle sometimes that my dials looses power and reboots.
    When that happens the dials show 9V before going black.
    (The dials has a direct connection from the battery and a signal input from the ignition).
    Can I add something as a buffer to stop this from happening, that given that this voltage drop is normal on these old bikes?
  9. bikeboy929
    bikeboy929 Member
    mahtomedi, mn
    this might help
    http://www.electrosport.com/media/pdf/f ... iagram.pdf
    if your bike is running right it shouldn't be at 9v, or 11v at idle( adding the extra 2 volts again, if i understood correctly.
    what kind of dials do you have? maybe try disconnecting them and test your voltage at idle with and with out them to see if they are pulling to much power.
  10. Polock
    does this bike run with the headlight on all the time? if so, try unplugging it and see what happens.
    sounds like the battery has seen better days.
