Battery wont keep a charge and its pissing me off!
Discussion in 'XJ Technical Chat' started by bobbytheblack, Oct 16, 2011.
  1. bobbytheblack
    bobbytheblack Member
    Seattle, WA
    So when I bought the bike it had trouble starting, so initially I bought a new battery, new spark plugs, made sure all the wiring was connected properly and blah, blah, blah; I charged up the new battery, I installed it... BINGO BANGO! :D
    I notcied it having a problem earlier, and then I went away for a month and now its dead. D-E-A-D! DEAD! :cry: I can jump it, but it'll die soon after. I installed my girls battery and BINGO BANGO! She's ALIVE! :eek:
    But sadly my GF, wants her battery back in her bike... selfish, just selfish. :roll:
    So I'm on my way to the Auto parts store to buy a battery charger, but can anyone help me with ideas as to why my battery is dying? :?
  2. Kwiski
    Kwiski Member
    High Desert CA.
    Get a cheap 12 volt tester. Remove the Ground wire from battery. If light comes on and there is no key on you have short to ground. Pull fuses till light goes off. Then check the circuit that was keeping the light on. Fairly simple. Can also use multi-tester. Also check the battery levels as with mine I have used a car type charger & it boils off the acid inside battery ( thus lowering level). Best one to use is trickle type charger.
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Check your alternator brushes to make sure they are in spec.
  4. RickCoMatic
    Place a Meter on the battery Terminals.
    Check for Charging Current.
    +14.2 -to- +14.5V at 2000 rpm and above.
    Pull Alternator Cover.
    Measure Brushes.
    10mm or less = Replace.
    Inspect Alternator Rotor.
    Brush Orbit "Paths" should be free from Scorching and Arcing damage.
    Clean Orbit Paths with Typewriter-style Eraser.
    "Wheel and Brush-type" Eraser.
    http://www.artfire.com/ext/shop/product_view/3070506
  5. bobbytheblack
    Seattle, WA
    Since I am most definitely more computer geek than mechanic, could someone point out or show me a picture of the alternator...
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Left side of engine as your sitting on the bike. Big round cover about the size of a softball. Three phillips screws that hold it on. Thats the cover you need to take off to get at brushes.
    But before you do that... Look at the connector on the wire harness that comes from that cover up under the tank and see if its melted. I have had those three wire connectors fail on several bikes now.
    Let us know what you find.
    MN
